HELP!!! No fuel. fuel pump not truning on
azn2nr
Post by azn2nr »
tried to start the swap today and it would turn over but not fire. havent checked the spark yet but i know for sure that there is no fuel. there is no pressure in the hose and no fuel in it either.
everything else so far is going good. no door chime, or airbag, or cel lights but batery and oil stay on. everything else is pluged in that i can find mates to. all others are asumed to be accsories that have yet to be pluged in. ie cruise, radio, ect.
how do i fix this? sugestions??
-jason
scuzzy
Re: HELP!!! No fuel. fuel pump not truning on
Post by scuzzy »
azn2nr wrote:tried to start the swap today and it would turn over but not fire. havent checked the spark yet but i know for sure that there is no fuel. there is no pressure in the hose and no fuel in it either.
check to make sure you're getting 12V at the fuel pump connector in the back.
#82 M4 TRSCCA Rallycross
azn2nr
Post by azn2nr »
there is no power to the connector
i tried to trace the wire back to the front to the relay box. switched the relay and now the fans dont even turn on like they used to
-jason
BAC5.2
Post by BAC5.2 »
Did the fuel pump turn on? Might have been a bad relay.
Oil light is on because you have zero oil pressure in the motor. Crank it until the light goes out before you start it.
azn2nr
Post by azn2nr »
i cranked it for days before i realized the fuel wasnt comming. fuel pump hasent turned on yet.
is it just a regualr relay or is it delear only.
-jason
Does the Check Engine light turn on when you turn the ignition switch on?
azn2nr
Post by azn2nr »
as of last attempt the cel turns on as soon as i put the key in. oil light never turns off.
-jason
Brian Mau
Post by Brian Mau »
It might sounds something stupid, but did you check the fuses in the fuse box? If they're all fine you might want to try to hot-wire the fuel pump and see if it's still working or not......
[url=http://www.cardomain.com/id/brianmau]MY92 Atmocharged GX AWD......[/url]
Brian
azn2nr
Post by azn2nr »
yeah all the fuses were in the fuse box and all of them were good. there are some out now but i dont try anything unless its in.
-jason
Matt Monson
Post by Matt Monson »
Did you use the Impreza or the Legacy fusebox in the engine bay?
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
azn2nr
Post by azn2nr »
they are all the same as far as i could tell. it is the box under teh dash that are different. but i can try to switch the box tomorow.
-jason
Wait, you switched the fuel pump relay and now the fans don't turn on? What fans are you talking about?
If you're talking about the blower, I think you found the blower motor relay rather than the fuel pump relay. They're both the same type of relay.
If you're talking about the radiator fan, why was the radiator fan coming on when the car wasn't started?
azn2nr
Post by azn2nr »
beats me. i just turn the key to acc adn fans come on. (rad fans)
im gonna tear it all apart and put it back together today. hopefully this solves something
-jason
azn2nr
Post by azn2nr »
tore the car apart again. no change.
new devlopment though. there were 2 male wire ends outside of their clip. black wires both of them. they were taped to 2 other wires that were in a clip. without checking i pluged them into the clip when i promptly realized. the clip was female. i cant get the wires out thus far after 3 hours of trying. i need a bigger needle methinks. it still bothers me that thoes 2 wires were sitting there like that.
-jason
Matt Monson
As I said on NASIOC, those wires were like that from the factory. I never touched them! You should not plug them in...
You really need to start systematically trying to trouble shoot this. Your current approach is like throwing darts with a blincfold on.
Step 1. Check for ECU power and that the main power relay is set up correctly...
Suby Hai!
azn2nr
Post by azn2nr »
i think its grounded wrong. i swear i have powers that are grounded and grounds that are not. i get power to the ecu if its grounded to one pin and no power if i switch grounds. is seriously pissing me off. and that dam oil light wont turn off. i cant figure this thing out. why couldnt everything stay correct instead of breaking [/rant]
-jason
