help: My cruise control likes to speed
snowjob
Post by snowjob »
Hi everyone, This group is great, I recently got a 92 legacy awd turbo for $250 from a dealer who just needed to get it off the lot, he needed the space. The car is awsome, but has one flaw. When I put on the cruise control, it increases in speed at about 5 kmph or 2.5miles an hour per kilometer traveled, before you know it, your really going fast. When I try and use the coast function, the car speeds up.
I'm not sure if this is related, but the speedo in the car also is not smooth, it jerks and when at a set position, ie. 3000rpm it bounces around. Could this be the prob??
I've replaced the switch at the steering wheel but has not helped.
Please help, I comute 1.5 hours a day, and the cruise is a nice feature to have at 5am.
Thanks in advance
Snowjob
Yukonart
Cradle Robber
Cradle Robber
Post by Yukonart »
I would most certainly put that speedo sender under a little scrutiny. In a car that old I'm sure it's possible that a replacement is necessary. :oops:
snowjob
Post by snowjob »
Thanks for the reply, Can you tell me were the speedo sendor is, and how I should go about replacing it. Could the speedo (the cable that exits the transmision and goes into the back of the gauge package be responsible)
Thanks for any help
Snowjob
speed sensor is in the back of the combination meter.
snowjob
Post by snowjob »
Thanks for the reply Josh, I'm afraid I'm not quite sure what the combination meter is, the guage cluster?? I've just looked thru my Haynes manual, and to be honest i'm stumped.
Can you steer mee in the right direction :?:
Snowjob
LaureltheQueen
Spelling Nazi
Spelling Nazi
Post by LaureltheQueen »
I'll take photos. I have a spare speedometer lieing around. :)
http://www.imagestation.com/picture/sra ... 06031a.jpg
where your speedo, tach, gauges are is called the combination meter.
There is also a speed sensor in the transmission, but it's used to run the AWD system.
snowjob
Post by snowjob »
If one was to replace the speedo, could you take the odometer out from the existing car and keep it when you put the new combinaiton meter in? IE. the current car has 140000km on the odometer, the parts car has 346000. I'd prefer to keep the 140 000, is it possib? Also what about the cable that goes from the tranny to the guage, could it cause erratic or harsh shifting??
Snowjob
I guess if the cable is not providing a smooth turning input to the speed sensor it could possible mess up shifting.....but you would probably see that on the gauge as well.
