Ive got a line on some heads for a good price, but the guy doesnt know what car they came from
I know theres like a phase 1 and a phase 2 or something
soooo
Whats the difference, which one is better, and are there any markings on the heads to disguish them?
Also, how hard is it to find cam sprockets?
All DOHC 2.5 heads the same?
Phase I EJ25 is DOHC
Phase II EJ25 is SOHC
There was a slightly lower power EJ25 in 1996, but the heads were probably the same. JDM and the new USDM heads featured versions of AVCS.
Chances are high that they're from a 97-99 Legacy.
Legacy Central
98 RS was DOHC, 99 was SOHC. Same for the Forester.
Legacy Central
Matt Monson
- quasi-mod-o
Same as a '97-99 Legacy or Forester. But '96 DOHC Ej25 have hydraulic lash agjusters in the buckets. Later ones are shim over bucket...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
This would require the use of an OBD-II ECU, or is the AVCS a more passive system than that?DLC wrote:There was a slightly lower power EJ25 in 1996, but the heads were probably the same. JDM and the new USDM heads featured versions of AVCS.
1994 & 2005 Legacy GT Wagons
The forester shared heads with the RS, as was mentioned.
AVCS would be phase II, so you wouldnt be able to run them with a phase I ecu without major cam gear work. But I do believe you can the AVCS unhooked, or disengaged.
The 96 hla buckets will be a smaller diameter as well.
1997 White BG Ltd 5MT, EJ22T with Wiescos, EJ20R Heads, Two large dents R.I.P
1995 Impreza EJ22T DOHC Hydra EMS, 20g, EWG, 3in APS TBE, AWIC
