Wastegate solenoid clicking
Hey so ive bypassed my OE wastegate control solenoid to run my manual controller. I have left the bottom vac line and electrical connector still connected. Now it seems that whenever i try and go WOT pre-boost it will click very loudly and i get a hesitation. But if i ease into boost before WOT it doesnt click loud enough to hear and boosts fine. My question is how much should this thing be clicking and should it be loud enough to hear in the car?
93 SS 5MT - TD05H-16G, 06 TMIC, Walbro, Zeitronix WB-02 - Scrapped too much rust
91 SS AT
97 Outback - Prodrive quick rack, DMS 40
91 SS AT
My cars controller would click when I had it hooked up to the factory stuff, basically it would work and the not work. I dont get why yours would create a hesitation, because it is just being driven, its not the one in charge. Do you have a FCD? Is the map sensor doing something wierd maybe?
You have to leave the electrical hooked up or you get a CEL. The bottom hose is just for the air that is being released back into the intake system. Hmm, Let me think........
this clicking, comes on right about when boost does? are you sure were not talking about wastegate flutter? i get really loud clicking and wastegate flutter, this is with everything hooked up. i have heard its just a weak spring, but i think it may be result of a boost leak and the turbo spinning faster throwing off wastegate duty cycles and it trying to work to hard resulting in flutter... just a thought
Plug all the vacuum line, so you dont get any vacuum leaks. Find another dropping resistor(like the one on the back of the presure sensor assembly. Plug the dropping resistor in where your wastegate solenoid goes. This gets rid of the clicking and prevents a CEL. Warning: the resistance of the resitor is a bit low, so it can get hot. I drove for at least 6 months with no problems to date.
1997 White BG Ltd 5MT, EJ22T with Wiescos, EJ20R Heads, Two large dents R.I.P
1995 Impreza EJ22T DOHC Hydra EMS, 20g, EWG, 3in APS TBE, AWIC
My post was for Threshld1 since he is using a MBC. If you unhook the soleniod you will only get 6lbs.
I believe that resistor is for the ABS. So if you are still using your ABS you should find another one from a JY, and leave the original one hooked up.
Im not sure what you mean by wastegate solenoid being 100% mechanical.
would it throw a CEL or cause any damage to the solenoid if i simply removed the vac line for now untill i either get another resistor or find something that will disipate the heat better. Essentially your suggesting to place a resistor in place of the solenoid to keep the circuit closed with a resistance as to not short it. so wouldnt a high wattage resistor of similar resistance work?
91 SS AT
91 SS AT
the only thing that plugging into that white resistor can hurt is the resistor itself, so unless your worried about ruining the pointless little resistor it should be fine.Threshld1 wrote:would it throw a CEL or cause any damage to the solenoid if i simply removed the vac line for now untill i either get another resistor or find something that will disipate the heat better. Essentially your suggesting to place a resistor in place of the solenoid to keep the circuit closed with a resistance as to not short it. so wouldnt a high wattage resistor of similar resistance work?
The resistor lets the ECU "see" that something is hooked up. So that it wont throw a cel. Yes, all you need is a resistor that is a high enough wattage at around 20 ohms I think. Just us a multimeter and measure the resistance of the solenoid, and get a resistor to match.Threshld1 wrote:would it throw a CEL or cause any damage to the solenoid if i simply removed the vac line for now untill i either get another resistor or find something that will disipate the heat better. Essentially your suggesting to place a resistor in place of the solenoid to keep the circuit closed with a resistance as to not short it. so wouldnt a high wattage resistor of similar resistance work?
A higher resistance may work also.
The only advantage to all this is to be able to remove the soleniod and not get a cel.
Be sure to plug the third hose so as to not lose metered air.
The dropping resistor is for the automatic transmision.napphappy wrote:I believe that resistor is for the ABS. So if you are still using your ABS you should find another one from a JY, and leave the original one hooked up.
Here's some pics
http://www.main.experiencetherave.com:8 ... istor1.jpg
http://www.main.experiencetherave.com:8 ... istor2.jpg
http://www.main.experiencetherave.com:8 ... istor3.jpg
