Will this work...?
supernoob
Will this work...?
Post by supernoob »
I just bought a 98 Leg Wagon with rod knock. I've got a 90 EJ22e block with 95 EJ18 heads on it sitting in my garage. Will the manifold from the 98 work on the 95 heads. If it doesn't, can I gasket match 'em. Or should I use the 95 manifold? Thanks.
sammydafish
Post by sammydafish »
2.2 or 2.5 in the 98? If it's a 2.2 it might fit, pretty sure the intake is the same, the exhaust will be different though, the 2.2 changedto single port in 96.
if the 98 wagon is a 2.5 it won't fit, you'd be better off with another EJ25
- Junior
90L Wagon EJ22E on Toyota CT-26 boost -- Crushed!
95L Wagon on T3/T4 boost :)
www.trdsupra.com [b][url=http://trdsupra.com/library/forsale/]Cheap parts![/url][/b][quote="Imprezive"]alright, I give up, I'm going to NASIOC...[/quote]
supernoob
Post by supernoob »
[quote="sammydafish"]2.2 or 2.5 in the 98? If it's a 2.2 it might fit, pretty sure the intake is the same, the exhaust will be different though, the 2.2 changedto single port in 96.
if the 98 wagon is a 2.5 it won't fit, you'd be better off with another EJ25[/quote]
Thanks sammy, its a 2.2.
