Edit this to add about my newb learning experiences.
The first repair I ever did (on my own) was a narrow band unheated O2 sensor for a 91 camaro Z28
I changed O2 sensors before I changed oil.
then I went from that to spark plugs, then about the third or fourth repair I did was a heater core - and boy was that a bitch, but a serious learning experience.
hood lifts (fun)
wheel bearings
disc brakes
and probably a million other things since then - not to mention my engine swap, first time ever by myself.
You are your own best teacher, someone else doesn't hurt, but hands on experience is the best way to learn.
One of the earliest things I worked on was a drivetrain swap into a friend's '96 Impreza. I was changing oil and basic maintenance before that, but that was my first major thing.
I'll second that. You can talk all day with someone about this sort of thing but you really won't get any experience until you get in there and just deux it.
Just be thankful you're starting out on a Subaru. I started on an OBD-II Saturn... much tougher to work with, especially for a beginner. Damn FWD transverse engines. I've never struggled so much to change a damn serpentine belt, or a water pump, or (good gawd never try this on a Saturn) an alternator... you damn near have to remove the engine to get at that one. And I have swapped engines on my old '92 Saturn (spun bearing on a junkyard car + junkyard engine from Hippy's Auto Salvage = $300 beater) - no amount of lecturing could have prepared me for that...
Subarus are very pleasant to work on IMO. Especially after the few *cough* Ford experiences I've had since then.
-Chris
91SS 4EAT stock, 200k mi
subarus are definitely not one of the easier cars to work on, especially to learn to work on. the flat 4 just kind of lends itself to complication. of course, that is what makes the EJ the coolest 4 banger in teh world.
anyone here ever had time under the hood of a volvo or fullsize truck? too easy. volvos especially are designed to be worked on. good thing, huh.
By that string of logic, you'd think that Fords would be the damned easiest vehicles to work on ever.
But that assumes that Ford designers follow some sort of logic and don't just toss engine components under the hood...
And I've found my Subaru very easy to work on, especially for regular maintenance items. It just seems as though it was designed to be serviced by the owner. I suppose LCO is to blame for my understanding of the boxer 4 though
-Chris
free5ty1e wrote:And I've found my Subaru very easy to work on, especially for regular maintenance items. It just seems as though it was designed to be serviced by the owner. I suppose LCO is to blame for my understanding of the boxer 4 though
Ever see your owner's manual? It has regular service stuff in it, things newer car manuals do not.
Newer cars are all about plastic covers over the engine and taking it to the dealer for oil changes.
For People that don't have People around that know Nhat they'e doing, Sometimes an auto class is a very good option to gain the Knowledge to dive into repairs not only safely, but Confidently. l Took 2O credits of auto shop,and it has immensely aided me in not only theory of OE Systems,but understandingof aftermarket and Performance systems. l'd Suggest it wholeheartedly.
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
I think if you compare them to their closest competitors, Subarus are actually very easy to work on.
Splinter, I think this course will be a good chance not only to learn this stuff in a structured way, but to meet some people who you can work with in the future. The concept of an apprenticeship is compelling.
I'd be very curious to hear whether you actually get a good treatment of the fundamentals and theory. It seems like a lot of trained mechanics I meet don't have as good a grasp as I do, even though I completely lack formal exposure to mechanical repair.
l've found that many mechanics don't quite Understand theory behind things very well, but most of them have little to no interest in the Performance aspect of cars, so don't really "need" to understand. l don't think that made any sense.
I've worked on lots of cars and Subarus are among the best. The few cars that are easier to work on (usually much older) are not as well engineered (sometimes requiring replacement of more parts than the original problem called for) and require work more often.
Ford sucks ass. My Mazda's bottom end is ford (2.3) and doing the oil filter takes over an hour. There's also a hole to access the oil filter from under the car without having to remove all the undershielding except the hole is about 4 inches from where the damn filter is necessitating the removal of said undershielding any-the-fuck-way! A hole saw will solve that, but you'd never see that kind of stupidity issue with a Subaru.
