Hi all new here
Townsville Liberty
Hi all new here
Post by Townsville Liberty »
Hi all new here and sayin hi
I just bought a 92 liberty lx 2.2l FWD manual, only paid $300 :-D .
now it was so cheep because it has 300000km's and needs a new motor because some bonehead cant line up the key way on the crank pully.
now me being what could be called young and stupid i want to replace it with an EJ20t and fit the AWD gearbox and rear driveline.
What do you think?
Originally Posted by Zefy
ahhhh... so many ideas, so lazy...:-p (not to meantion complete lack of $)
1st gear is just like foreplay, it's ok, but you want it to go as fast as you can and get it out of the way so you can get into the real sh*t!
Townsville Liberty
Bump, any ideas
Splinter
Post by Splinter »
For the AWD swap, you might want to look at Josh's sticky in the driveline thread
It'll be a LOT of work, and will most likely cost you a lot more than just buying a liberty gt
Unless the body and interior is mint, you might want to heavily consider your options
And welcome to the forums!
Post by 555BCTurbo »
Liberty RS* :D
Splinter
Post by Splinter »
Foreign model names spin my head.
At least I tried :P
bmxkelowna
Post by bmxkelowna »
hey and welcome to the board!
your car has the black peice on the trunk (boot :P) right? want to trade for a usdm one? :)
Townsville Liberty
bmxkelowna wrote:hey and welcome to the board!
Yeah it has and wats the "usdm" one?
Thanks y is it going to be so much work? everything should just bolt up wont it? i figer ill have to replace the fuel tank and entire rear crossmember etc. i have converted a holden commodore to a manual and a magna wagon to a 3.5l and manual were told on both ocasions it couldnt be done but we did and it wasnt that hard why would this be any different? (please dont take that the wrong way)
PS im a mechanic at a soob dealer and have acess to several vehicle hoists and workshop manuals along with the subaru scan tools not that they help on the early soobs
Also im plannin on usin the late model ej20t quad cam wit vvt out of say a wrx also with an aftermarket ecu and a fmic
IronMonkeyL255
Post by IronMonkeyL255 »
It should be easy, then, to convert to AWD.
I think the reason that was said is that you do have to replace quite a few things to get it to work right.
Off the top of my head:
Subframe
Fuel Tank
Lateral links (I think)
Knuckles/hubs
Rear struts/springs
If you can get all that from a donor car easily, it should be good.
Rio Red '91 Legacy SS
Splinter
Post by Splinter »
The biggest problem I see is this:
Wiring.
You'll have to replace a huge chunk of the wiring harness in order to run the turbo ECU
Splinter wrote:The biggest problem I see is this:
Wiring.
Not really.
Remember....my car was originally FWD, AT, & N/A. It's now AWD, MT, & Turbo.....
The turbo conversion only required swapping two pins for the cam & crank sensors, and adding leads for the turbo specific sensors.
Matt Monson
Post by Matt Monson »
Wiring.
Not really.
That would be true if he was going with an early swap. But it sounds like he wants to do a v7 or newer Ej205 or Ej207 swap in there. Note he said with VVT (aka AVCS). That's a completely different level of wiring than putting an Ej20G or EJ22T into it. It's basically just like doing a swap on any GC impreza.
The easiest approach is to get the complete wreck and pull the wiring harness into the car complete. This will require/allow you to replace the old dash with the modern one at the same time. This sounds like a fun project, and it will be one helluva sleeper once it's all said and done...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Splinter
Post by Splinter »
Well I was right, but apparently for the wrong reasons :P
Oops....didn't read that he was going with a later setup.
bmxkelowna
liberty
legacy
Townsville Liberty
liberty
legacy
Yeah ok but dont forget im in Australia.
Are the tail lights different? dont look like it. pm me if ya want to get in to details about it
Townsville Liberty
Richard
Post by Richard »
What are those two things on top of your rear bumper?
scottzg
Post by scottzg »
Richard wrote:What are those two things on top of your rear bumper?
license plate lights.
crawlerdan
Vendor
Vendor
Post by crawlerdan »
i would love to trade my 94 leg turbo trunck panel for a liberty!!! if some one wants to do that lemme know!!!
HomeSlice
Post by HomeSlice »
euro tails have rear fogs thats about it.
bmxkelowna wrote:
Townsville Liberty wrote: Yeah it has and wats the "usdm" one?
93BC"edm" 93GC 90BC R.I.P.
Townsville Liberty
ok kool
