oil squirters torque specs
not8player
Post by not8player »
Anyone has an idea of the torque spec for the EJ22T oil squirters? From what I gathered from searching the forum Loctite is a must for the oil squirters.
I am stuck reusing the original aluminum little washer, should I put a bit of sealant around the washers?
thehookeup
Post by thehookeup »
the torque spec is snug and then just a lil more. not much more than a single hand can turn with a ratchet... loctite i think is optional. i didnt use loctite. but a smal drop couldnt hurt... and i woulnt worry about putting sealant around the washers. if they leak which will only happen if you really really do something wrong, it will prolly just drop oil pressure. but youll never leak outside the motor
-93 2.2T (RIP), 93 N/A best car on earth.
-00 legGT, 18" PIAA sport mesh wheels, front/rear Rallitek sways, lowered whitelines, coming soon: 2.5L sti internals, 20g heads P&P, twin charged. motor is almost ready to go in.
Andrew
not8player
thank you for the reply! :-)
napphappy
Post by napphappy »
I would recomend the loctite, and make it red. They have been known to fall out. And you dont want to be losing oil pressure, especially there at the mains.
1997 White BG Ltd 5MT, EJ22T with Wiescos, EJ20R Heads, Two large dents R.I.P
1995 Impreza EJ22T DOHC Hydra EMS, 20g, EWG, 3in APS TBE, AWIC
