Im trying to take apart my blown front diff (dont ask why). I undid the two bolts next to the things that surround the axle stubs that are covered in little teeth/notches, and figured those things were basically big threaded plugs. So I break out the hammer and punch, and start spinning them. 5-6 broken teeth later, and they dont seem to have move in any direction except around in a circle.
How do you get them out so you can get the crown/orbit dealie out?
Disassembling 4EAT front diff
Radial GT1
goddamn, looks like you broke a halfshaft there.
wth did you do to it? lol
anyway, that's just the output shaft, the differential - if it's anything like a manual (it should be) is located inside the case and is mounted to a huge reduction gear - it's a small device in comparison to the reduction gear itself.
anyway, to get to it you've got to drop the transmission and split the casing. although I dunno how you would go about it on an automatic.
I'd just throw the thing away.
#82 M4 TRSCCA Rallycross
IronMonkeyL255
That sounds so much like me it's scary.Splinter wrote: Im just taking it apart for reasons that are my own
"I already replaced the broken part, and now I'm disassembling it for the hell of it, or maybe just to see what makes it tick..."
Hell.... I tore apart my old o2 sensor just to see what was in it.
Rio Red '91 Legacy SS
