Starter motors Manual/Automatic
kidge007
Post by kidge007 »
Help
Just swapped a auto engine into a manual, and I wonder if I have managed to get the starters confused.
Which way round is it?
Short nose starter= Auto/MT
Long nose starter=Auto/MT
Problem is that the starter just clicks but only sometimes spins the engine. Have had the starter re-built, works fine on the bench. But stilll the same in the car???
Subaru for Life
Post by Subaru for Life »
The manual tranny starter = short (1.0 kw)
The Auto tranny starter = long (1.4 kw, also has screws in body of motor).
Check the solenoid, good luck.
Pye
kidge007
Post by kidge007 »
Found my own problem.
Voltage drop down the signal wire to the starter.
Could'nt be bothered to find the problem in the loom so I wired in a relay and all is well. 8)
However.....I have the long nose starter in a manual.....and it works
vaccine
Post by vaccine »
long is manual, and short is auto ;)
.. Dave
