needing help plz
bigjb05
needing help plz
where do you guys find the front and rear strut tower braces for the wagons at any help would be appriceated. and what is the best suspension upgrades to do on my car. 91L 5 spd 160,000 miles
Welcome to the board.
It took me a while to use the search feature.
Give it a try.
Dont know where tn is, let alone east tn
However, it is likely that a rear strut brace would be more effective than the front one.
Give it a try.
Only C, F, J, and M share the same bolt pattern and spacing. D, E, G, H, and K fronts have the same bolt pattern but the orenitation is different, so no go. Rears have the same spacing but the bolt pattern is different.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
Considering the price of swaybars I'm going to have to disagree with that.
bigjb05
sorry to change the subject but i done got the brace and going to install it today. but i cant understand the compedium thing. i need new struts and had my eye on the kyb gr2 but i was wondering what all i will need to do this i am fairly car orientied and will be going to Nashville auto deisel college in october.
One has to think like scott inorder to understand the compendium. To make it short, GR2's will bolt right on to whatever you're using.
That's about what they go for here with the current conversion rate, and I'll stand by it that that's bad bang for buck.
scottzg
what can i do to make the compendium more easy to understand? It makes perfect sense to me, although one would hope it would since its mine.THAWA wrote:One has to think like scott inorder to understand the compendium. To make it short, GR2's will bolt right on to whatever you're using.
I'm quite serious. Compare that price to a set of half way decent tires, about twice the price here for four tires vs one swaybar. Which would help in more places than the sway bars would: accel, braking, turning.
in australia AUST$400 wont buy any new tyre that i would put on. a full set of Toyo T1R's or similar Bridgestones, we are looking at $250 a corner. = $1000... swaybar $200.. sold x 2, plus both braces and lower front brace! you must get tyres pretty cheap.. though your fuel is as well, bastards!THAWA wrote:Compare that price to a set of half way decent tires, about twice the price here for four tires vs one swaybar.
you are not wrong.. bald tyres and big rear swaybar, and a dccd centre locked at 35:65 rear, makes for some great corner fun.scottzg wrote:crap tires and a huge rear bar sound like a lot of fun.
then just add some water..
.. Dave
Better to just install a rwd center diff, I would think.
