201 whp and 255 torque with a 50 hp nitrous shot and WAY TOO BIG fuel jet.
Had the fuel jet been smaller, I probably would have hit about 220 whp.
I dynoed at PRE in Greshem. This week is just $35 for 3-4 pulls as they get the kinks worked out. Normally it will be about $65 with wideband.
I ran 13's with 8 psi boost and 100 shot of nitrous. Now I am at 10-14 psi (depending upon gear) and should be just shy of the 13.99 mark on boost alone.
Well, with a bigger turbo and downpipe, Kelley made 215 whp at 18 psi before fuelcut. At 8 psi on the same dyno I made 155.
So I bet if you have a fuel cut defender, you win! Get that baby running!
I fixed some of my boost leaks and am now running 13ish psi. So I am probably making a tad over 200 at the wheels now. If only I can keep the damn piping from popping off!
I am, but the piping doesnt have the lips on them......
maybe take the pipes to an exhaust shop and have them put a little flare in them, they have these crazy expanding die things for doing it to exhaust pipe. just a slight flare on the end would probably be all you would need eh?
Its Kelly Doug. KELLY. no EY, or IE. Shit, it says it right down there in my sig. I think we've been friends long enough now, for you to spell my name correctlly.
Imma start calling you Dog. Or like Sue, or maybe Dick from now on.
Congrats on the numbers, but my car is still faster.
