MAF Question - Interchangeable?
realfinn
Post by realfinn »
Ok, so I have read a lot of threads on MAF sensors. I have gathered from them that the 93 EJ22T has a "aluminum" MAF and that the early NA also had aluminum MAFs. I am doing my swap 93 SS into 91 NA and I was wondering if the MAF was interchangeable. I looked on them both for identification and the numbers seem to be the same (other than the hot stamped letters - I'm guessing that this is a factory date code of some sort). Visually everything seems to be the same. Can I use one on the other?
Yes they're interchangable.
