Keyless entry problem 95 Legacy
MikeC5
Post by MikeC5 »
I know it's a 95 but maybe someone can point me in a direction for info on getting the keyless to work. The P.O. bought a new key fob after losing the original but couldn't get it to work. I tried replacing the battery, no luck. Any clues?
Josh Long
Post by Josh Long »
Find the keyless entry box under the dash if it has one. ( it will be needed for this) and depress the black button that hangs from it's wiring loom, while depressing the lock button on the fob. Your doors should now lock and or unlock.
Good luck
97 Legacy Outback 2.4ish turbo
MikeC5
Post by MikeC5 »
Thanks Josh. Might you have any idea which side or any other clues to the specific location?
Manarius
Post by Manarius »
Umm, on the 95 I think it's under the glove box or thereabouts.
MikeC5
Post by MikeC5 »
Thanks!
smidge
Post by smidge »
hey guys having a similar problem on my 96 legacy.....
i've pulled the keyless box out of the dash but haven't found any button to press on the loom ???
occasionally if i point the key fob really close to the infrared sensor the locks will snap locked and then snap unlock again.... but then won't work for a while afterwards....
the central locking works fine with the key however...
anyone have any ideas? this has been driving me nuts!!
cheers
