I Found a Swap!!! finally.
It's been a while since I've been on the board. Soooooo much to read. I have found a near complete setup from a jdm 98 WRX STi!! The engine, intercooler, acessories, ECU, wiring harness, axles, transmission, shifter, driveshaft, rear diff, and engine mounts are usable. The odo says 74,000 Km. Im still drivng my 94 legacy Ti (now rid of the air suspension in favor of a AGX/Whiteline setup). What can I use and will that TMIC fit?
Cody
1994 Legacy Ti Wagon (Estate)
2.4L of N/A fury :)
Awesome vendor: http://home.att.net/~teaguesauto/index.htm
2.4L of N/A fury :)
Re: I Found a Swap!!! finally.
You can use the engine, intercooler, accessories, ecu, wiring harness, axles, transmissino, shifter, rear diff, and engine mounts.STi_GUY wrote:It's been a while since I've been on the board. Soooooo much to read. I have found a near complete setup from a jdm 98 WRX STi!!
![Wink ;)](./images/smilies/icon_wink.gif)
course, i'd go for a standalone before i used that ECU. Autronic makes a plug and play board for ya.
![Very Happy :D](./images/smilies/icon_biggrin.gif)
-Jason Grahn
Damn. Just my day. The lot of it went to a higher bidder. It sux being poor. I did however find a EJ20TT with trans, wiring harness, ecu, and accessories on Ebay. Tons cheaper, too. 1,750 USD + s&h vs 5,300. Under 50K on the clock. Good Swap? Let me know.
Cody
2.4L of N/A fury :)
2.4L of N/A fury :)
- Vendor
Errr..you swap people..
Hey! *smack* E-bay is alright but if you want a good deal, deal with the importers.
I've talked with these guys, it's all in austrailian dollars which means if it says the engine is 3500 with trans, it's 1500... they also sell front cuts for the SAME price, so then all you have to do is put the 2 engines side by side and figure out what one has that the other dosen't makes things like wireing a bit simpler.
![Image](http://www.adelaidejap.com.au/images/WRX_front.jpg)
They love dealing with us Yanks. i've ordered injectors and intercoolers from them in the past.. no worry mate.
They offer packages as well in their engines section,
Hopefully this helps you in your swap search. Oh and don't be worried about shipping, they quote 800AUS to ship to the west coast..which again is 400US..so after looking at thier prices you will be way under your e-bay prices
David Carter
P.S. if you MUST shop e-bay try :
http://www.stores.ebay.com/enginesrus if they don't have what your looking for contact them..they will look for you.
David Carter
91 Subaru Legacy LS 2.2l FWD WGN
91 Subaru Legacy SSDN 2.2t AWD
