Have been noticing slight slippage of the clutch on my 92 SS. noticed the first time about a month ago, while using cruise control on some uphill slopes, noticed the tach needle bounce to a higher level then drop back down. have been continue driving it, and finally today it has gotten worse. I start a new job 70 miles away 1 way, start on Monday. I cant risk getting broke down that far away.
My TW is in dire need of some brakes for the front, it is metal to metal and that is why i stopped driving it. I have the new pads for it, so will swap them out tomorrow, but i still have to throw a battery in the TW. Guess that will be my daily driver until i get enough cash to buy the clutch for the 92
shit this suks,.
so, the clutch is slipping more and i start a new job 60mile
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
Re: so, the clutch is slipping more and i start a new job 60
yepBheinen74 wrote:shit this suks,.
OE Clutches are cheap yo. $349.01 for the Exedy OEM WRX clutch. Resurface your flywheel, probably for about $100, and you are golden.
Granted my NA is different, but I got a clutch for $159. A local shop resurfaced the flywheel for $30. I don't know what a turbo clutch is on the low end, but that and a Haynes manual is your friend. If you get ambitous, you and a couple freinds could do it in a weekend.
OE clutches are $349.01. I've got like 2 in stock, if you want, I can ship it out on monday. If it were me, I wouldn't gamble with a cheapie clutch.
Assuming things go smoothly, you can do the job one saturday.
The important thing is that you do it correctly, once. Don't just replace the disc, get a kit. Replace the TOB, Pilot Bearing, resurface the flywheel, and of course the clutch disc and pressure plate.
