Picked up 02 WRX suspension
Splinter
Post by Splinter »
Springs, struts and tophats with about 12,000km on them. $250
:D
Anything tricky about installing them or should they bolt up?
Imprezive
Post by Imprezive »
Rear top mounts wont work, you have to either drill holes or buy Group N mounts. If you try using your stock rear top mounts you cannot use the wrx springs. The front should be good to go.
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
jamal
Vendor
Vendor
Post by jamal »
Actually you just need to use your rear tops and spring perches with the strut and spring. You will have a degree or more less negative camber all around though.
Imprezive
Post by Imprezive »
Do the 92'-94' have un-tappered springs???
1988 4Runner RIP
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
jamal
Vendor
Vendor
Post by jamal »
yes it is also in the sticky about impreza springs.
tris91ricer
Title Whore
Post by tris91ricer »
Cool, Splinter! I also just got 02 wrx suspension, but its for a wagon . . Bfd, if you ask me. I'm throwing on the gn tops and some 05 sti springs. :cool:
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
Splinter
Post by Splinter »
Front strut assembly went in without a hitch, ride height looks to be almost exactly the same.
