Disspelling the MAF MIFF
NICO
Post by NICO »
with the plate of it cools the hotwire off faster in turn gives a slower hotwire response. if you add more psi then its hotwire. fuel table showed a slower response in high boost levels, which makes tuneing the stock maf much easy.
subaru of japan made them special, a removing plate. but dont remove it!! why?
hotwire plate on = makes more heat on hotwire in turn gives a smallfast fuel table 7psi tops.
hotwire plate off = less heat fastercooling hotwire in turn gives a largerslower response time on hotwire heat up time. i did not max it out yet, but looks like 21 22psi it wont read no more. 18g might have a candle effect on the rare 1991 subaru legacy turbo.
douglas vincent
Post by douglas vincent »
I have data logged both plate on, and plate off. Both spiked to 5.6 volts.
IT DOESNT WORK.
Period.
NICO
Post by NICO »
your wrong, you dont have nothing to data log it with. you dont have a chip makeing computer or a dyno or a japanese computer that can even read the dame ecu, neetronics does.
what you useing a piggy back system and vrg3 scantool. i have the factory scan tool from subaru and it even shows a diffrence in maf.
why is it so fuck hard to belive any way? is it becuse i found it out first in the world and everyone got to PLAY HATE.
go to neetronics and get your car tuned then will see who is made a fool.
douglas vincent
Its called a MAF. This is a MAF
This is an ECU.
They are two different things.
OK?
The ECU CANNOT CHANGE THE ACTUAL SIGNAL COMING OUT OF THE MAF!!!!!
Yes, it can modify it, but it CANNOT change it.
Why is it hard to believe, because we offer PROOF, you don't. Thats why.
Oh, and by the way, here is a data log.
Digital Technology
Perfect Power SMT6 data logg: 07-19-2006 21:41:36
File name: SMT6.007
Time ,Comm Cnt ,RPM ,Deflection ,AMP Input ,Engine T ,AFR OXY ,AFR Input V ,Analog Input V ,Analog Mod ,Analog Output V
21:41:37, 0, 752, 94, 0.2, 106, 14.6, 0.76, 0.9, -11, 0.75, 0, 2, 1, 14, 1, 113
21:41:37, 1, 752, 94, 0.2, 113, 14.6, 0.75, 0.9, -11, 0.75, 0, 2, 1, 14, 1, 113
21:41:37, 2, 754, 93, 0.2, 106, 14.6, 0.74, 0.9, -11, 0.75, 0, 2, 1, 14, 1, 113
21:41:37, 3, 757, 94, 0.2, 106, 14.6, 0.75, 0.86, -11, 0.75, 0, 2, 1, 14, 1, 113
21:41:37, 4, 761, 94, 0.2, 106, 14.6, 0.76, 0.9, -11, 0.75, 0, 2, 1, 14, 1, 113
21:41:37, 5, 768, 89, 0.2, 105, 14.6, 0.75, 1.25, -11, 0.82, 0, 2, 1, 14, 1, 113
21:41:38, 0, 770, 89, 0.2, 106, 14.6, 0.75, 1.45, -11, 1.02, 0, 2, 1, 14, 1, 113
21:41:38, 1, 804, 88, 0.2, 106, 14.6, 0.74, 1.53, -11, 1.1, 0, 2, 1, 14, 1, 113
21:41:38, 2, 905, 88, 0.2, 106, 14.6, 0.77, 1.57, -11, 1.14, 0, 2, 1, 14, 1, 113
21:41:38, 3, 1107, 87, 0.2, 107, 14.6, 0.75, 1.57, -7, 1.29, 0, 2, 1, 14, 2, 114
21:41:38, 4, 1213, 88, 0.2, 106, 14.7, 0.44, 1.57, -7, 1.29, 0, 2, 1, 14, 2, 114
21:41:38, 5, 1260, 88, 0.2, 107, 26.4, 0, 1.57, -7, 1.29, 0, 2, 1, 14, 2, 114
21:41:38, 6, 1446, 88, 0.2, 108, 26.4, 0, 1.61, -7, 1.33, 0, 2, 1, 14, 2, 114
21:41:38, 7, 1560, 88, 0.2, 105, 26.4, 0, 1.65, -7, 1.37, 0, 1, 1, 14, 3, 115
21:41:38, 8, 1682, 87, 0.2, 105, 26.4, 0, 1.76, -7, 1.49, 0, 0, 1, 14, 3, 115
21:41:38, 9, 1802, 86, 0.2, 105, 26.4, 0, 1.88, -7, 1.61, 0, 0, 1, 14, 3, 115
21:41:38, 10, 1908, 85, 0.2, 108, 26.4, 0, 1.88, -6, 1.65, 0, 0, 1, 14, 4, 116
21:41:39, 0, 1972, 86, 0.2, 104, 26.4, 0, 1.96, -6, 1.73, 0, 0, 1, 14, 4, 116
21:41:39, 1, 2036, 86, 0.2, 107, 18, 0.01, 1.92, -6, 1.69, 0, 0, 1, 14, 4, 116
21:41:39, 2, 2082, 86, 0.2, 105, 15, 0.06, 1.96, -6, 1.73, 0, 0, 1, 14, 4, 116
21:41:39, 3, 2137, 85, 0.2, 105, 14.9, 0.1, 1.88, -6, 1.65, 0, 0, 1, 14, 4, 116
21:41:39, 4, 2185, 85, 0.2, 105, 14.7, 0.44, 1.92, -6, 1.69, 0, 0, 1, 14, 4, 116
21:41:39, 5, 2181, 83, 0.2, 105, 14.6, 0.68, 2.08, -5, 1.88, 0, 0, 1, 14, 4, 100
21:41:39, 6, 2185, 82, 0.2, 107, 14.6, 0.6, 2.27, -5, 2.08, 0, 0, 1, 14, 4, 100
21:41:39, 7, 2179, 82, 0.2, 106, 14.6, 0.67, 2.2, -5, 2, 0, 0, 1, 14, 4, 100
21:41:39, 8, 2159, 82, 0.2, 106, 14.6, 0.72, 2.24, -5, 2.04, 0, 0, 1, 14, 4, 100
21:41:39, 9, 2149, 82, 0.2, 106, 14.6, 0.71, 2.24, -5, 2.04, 0, 0, 1, 14, 4, 100
21:41:39, 10, 2123, 82, 0.2, 107, 14.6, 0.73, 2.2, -5, 2, 0, 0, 1, 14, 4, 100
21:41:40, 0, 2110, 83, 0.2, 106, 14.6, 0.74, 2.2, -5, 2, 0, 0, 1, 14, 4, 100
21:41:40, 1, 2071, 83, 0.2, 104, 14.6, 0.77, 2.12, -5, 1.92, 0, 0, 1, 14, 4, 100
21:41:40, 2, 2035, 83, 0.2, 105, 14.6, 0.77, 2.12, -5, 1.92, 0, 0, 1, 14, 4, 116
21:41:40, 3, 1961, 84, 0.2, 105, 14.6, 0.78, 2.12, -6, 1.88, 0, 0, 1, 14, 4, 116
21:41:40, 4, 1903, 83, 0.2, 105, 14.6, 0.77, 2.12, -5, 1.92, 0, 0, 1, 14, 4, 100
21:41:40, 5, 1829, 83, 0.2, 104, 14.6, 0.78, 2.12, -6, 1.84, 0, 0, 1, 14, 4, 116
21:41:40, 6, 1772, 83, 0.2, 105, 14.6, 0.76, 2.12, -7, 1.84, 0, 0, 1, 14, 3, 115
21:41:40, 7, 1737, 83, 0.2, 107, 14.6, 0.74, 2.12, -7, 1.84, 0, 0, 1, 14, 3, 115
21:41:40, 8, 1662, 83, 0.2, 108, 14.6, 0.65, 2.08, -6, 1.84, 0, 0, 1, 14, 3, 99
21:41:40, 9, 1607, 83, 0.2, 111, 14.7, 0.49, 2.04, -7, 1.76, 0, 0, 1, 14, 3, 115
21:41:40, 10, 1561, 83, 0.2, 108, 15.2, 0.04, 2, -7, 1.73, 0, 0, 1, 14, 3, 115
21:41:41, 0, 1553, 83, 0.2, 107, 26.4, 0, 1.96, -7, 1.69, 0, 0, 1, 14, 3, 115
21:41:41, 1, 1586, 83, 0.2, 106, 26.4, 0, 2, -6, 1.76, 0, 0, 1, 14, 3, 99
21:41:41, 2, 1723, 82, 0.2, 107, 26.4, 0, 1.96, -6, 1.73, 0, 0, 1, 14, 3, 99
21:41:41, 3, 1808, 83, 0.2, 105, 23.8, 0, 2.04, -6, 1.8, 0, 0, 1, 14, 3, 99
21:41:41, 4, 1822, 82, 0.2, 105, 18, 0.01, 2.08, -6, 1.84, 0, 0, 1, 14, 3, 99
21:41:41, 5, 1860, 82, 0.2, 105, 15.7, 0.04, 2.12, -5, 1.92, 0, 0, 1, 14, 4, 100
21:41:41, 6, 1953, 82, 0.2, 108, 14.8, 0.23, 2.2, -5, 2, 0, 0, 1, 14, 4, 100
21:41:41, 7, 2039, 82, 0.2, 110, 14.6, 0.74, 2.24, -5, 2.04, 0, 0, 1, 14, 4, 100
21:41:41, 8, 2090, 81, 0.2, 105, 14.6, 0.76, 2.24, -5, 2.08, 0, 0, 1, 14, 4, 100
21:41:41, 9, 2135, 81, 0.2, 108, 14.6, 0.75, 2.24, -5, 2.04, 0, 0, 1, 14, 4, 100
21:41:41, 10, 2212, 80, 0.2, 105, 14.6, 0.75, 2.24, -5, 2.04, 0, 0, 1, 14, 4, 100
21:41:42, 0, 2281, 80, 0.2, 106, 14.6, 0.75, 2.24, -4, 2.08, 0, 0, 1, 14, 5, 101
21:41:42, 1, 2363, 80, 0.2, 106, 14.6, 0.73, 2.31, -4, 2.16, 0, 0, 1, 14, 5, 101
21:41:42, 2, 2418, 80, 0.2, 106, 14.6, 0.74, 2.31, -4, 2.16, 0, 0, 1, 14, 5, 101
21:41:42, 3, 2481, 80, 0.2, 106, 14.6, 0.75, 2.35, -4, 2.2, 0, 0, 1, 13, 5, 101
21:41:42, 4, 2553, 80, 0.2, 109, 14.6, 0.77, 2.43, -4, 2.31, 0, 0, 1, 14, 5, 101
21:41:42, 5, 2615, 80, 0.2, 107, 14.6, 0.77, 2.43, -4, 2.31, 0, 0, 1, 14, 5, 101
21:41:42, 6, 2687, 80, 0.2, 104, 14.5, 0.79, 2.47, -4, 2.31, 0, 0, 1, 14, 6, 102
21:41:42, 7, 2763, 79, 0.2, 106, 14.5, 0.79, 2.51, -4, 2.31, 0, 0, 1, 14, 6, 102
21:41:42, 8, 2817, 79, 0.2, 106, 14.5, 0.79, 2.51, -4, 2.35, 0, 0, 1, 14, 6, 102
21:41:42, 9, 2875, 80, 0.2, 105, 14.5, 0.79, 2.47, -4, 2.31, 0, 0, 1, 14, 6, 102
21:41:42, 10, 2943, 82, 0.2, 103, 14.5, 0.8, 2.27, -4, 2.12, 0, 0, 1, 14, 6, 102
21:41:43, 0, 2897, 93, 0.2, 105, 14.5, 0.8, 1.1, -4, 0.94, 0, 0, 1, 14, 6, 118
21:41:43, 1, 2825, 93, 0.2, 104, 14.4, 0.82, 0.94, -4, 0.78, 0, 0, 1, 14, 6, 118
21:41:43, 2, 2747, 93, 0.2, 104, 14.5, 0.79, 0.9, -4, 0.78, 0, 0, 1, 14, 6, 118
21:41:43, 3, 2675, 93, 0.2, 109, 14.5, 0.79, 0.67, -4, 0.75, 0, 0, 1, 14, 6, 118
21:41:43, 4, 2581, 93, 0.2, 105, 14.6, 0.78, 0.75, -5, 0.75, 0, 0, 1, 14, 5, 117
21:41:43, 5, 2470, 93, 0.2, 105, 14.5, 0.78, 0.94, -5, 0.78, 0, 0, 1, 14, 5, 117
21:41:43, 6, 2374, 94, 0.2, 104, 14.6, 0.76, 0.98, -5, 0.78, 0, 0, 1, 14, 5, 117
21:41:43, 7, 2249, 89, 0.2, 106, 14.6, 0.72, 1.33, -5, 1.18, 0, 0, 1, 14, 5, 117
21:41:43, 8, 2201, 80, 0.2, 104, 26.4, 0, 2.31, -4, 2.2, 0, 0, 1, 14, 5, 101
21:41:43, 9, 2131, 78, 0.2, 104, 26.4, 0, 2.35, -5, 2.12, 0, 0, 1, 14, 4, 100
21:41:43, 10, 2065, 78, 0.2, 108, 26.4, 0, 2.39, -5, 2.2, 0, 0, 1, 14, 4, 100
21:41:44, 0, 1894, 79, 0.2, 105, 21.2, 0.01, 2.47, -5, 2.2, 0, 0, 1, 14, 4, 100
21:41:44, 1, 1703, 78, 0.2, 105, 14.8, 0.24, 2.86, -6, 2.67, 0, 0, 1, 14, 3, 99
21:41:44, 2, 1757, 78, 0.2, 104, 14.5, 0.79, 3.02, -6, 2.78, 0, 0, 1, 14, 3, 99
21:41:44, 3, 1892, 78, 0.2, 105, 14.5, 0.8, 3.02, -5, 2.86, 0, 0, 1, 14, 4, 100
21:41:44, 4, 1931, 78, 0.2, 105, 14.5, 0.8, 3.06, -5, 2.9, 0, 0, 1, 14, 4, 100
21:41:44, 5, 1929, 77, 0.2, 105, 14.5, 0.79, 3.06, -5, 2.9, 0, 0, 1, 14, 4, 100
21:41:44, 6, 2046, 76, 0.2, 105, 14.5, 0.78, 3.22, -5, 2.98, 0, 0, 1, 14, 4, 100
21:41:44, 7, 2091, 73, 0.2, 105, 14.6, 0.77, 3.29, -5, 3.02, 0, 0, 1, 14, 4, 100
21:41:44, 8, 2151, 69, 0.2, 107, 14.6, 0.77, 3.25, -4, 3.33, 0, 0, 1, 14, 4, 84
21:41:44, 9, 2243, 65, 0.2, 105, 14.6, 0.77, 3.45, -4, 3.18, 0, 0, 1, 13, 5, 85
21:41:44, 10, 2299, 62, 0.2, 103, 14.5, 0.8, 3.73, 0, 3.41, 0, 0, 1, 13, 5, 69
21:41:45, 0, 2358, 60, 0.2, 103, 14.4, 0.83, 3.8, 0, 3.45, 0, 0, 1, 14, 5, 69
21:41:45, 1, 2444, 59, 0.2, 104, 14.4, 0.83, 3.61, 0, 3.61, 0, 0, 1, 14, 5, 69
21:41:45, 2, 2555, 60, 0.2, 103, 14.4, 0.83, 3.8, 0, 3.8, 0, 0, 1, 13, 5, 69
21:41:45, 3, 2665, 60, 0.2, 104, 14.4, 0.83, 3.65, 0, 3.8, 0, 0, 1, 14, 5, 69
21:41:45, 4, 2778, 64, 0.2, 105, 14.3, 0.85, 3.61, 0, 3.8, 0, 0, 1, 13, 6, 70
21:41:45, 5, 2704, 71, 0.2, 107, 14.3, 0.85, 3.73, -3, 3.69, 0, 0, 1, 14, 6, 86
21:41:45, 6, 2644, 87, 0.2, 103, 14.3, 0.85, 3.06, -4, 2.86, 0, 0, 1, 14, 6, 118
21:41:45, 7, 2576, 93, 0.2, 104, 14.2, 0.88, 2.63, -4, 2.47, 0, 0, 1, 14, 6, 118
21:41:45, 8, 2370, 93, 0.2, 104, 14.6, 0.77, 2.51, -5, 2.31, 0, 0, 1, 14, 5, 117
21:41:45, 9, 2372, 93, 0.2, 104, 14.6, 0.66, 1.73, -5, 1.53, 0, 0, 1, 14, 5, 117
21:41:45, 10, 2282, 93, 0.2, 108, 14.6, 0.59, 0.71, -5, 0.75, 0, 0, 1, 13, 5, 117
21:41:45, 11, 2157, 93, 0.2, 108, 14.6, 0.57, 0.94, -6, 0.75, 0, 0, 1, 14, 4, 116
21:41:46, 0, 2063, 91, 0.2, 105, 14.6, 0.57, 1.18, -6, 0.94, 0, 0, 1, 14, 4, 116
21:41:46, 1, 1971, 78, 0.2, 105, 14.7, 0.55, 2.31, -5, 2.12, 0, 0, 1, 14, 4, 100
21:41:46, 2, 1947, 75, 0.2, 105, 14.6, 0.74, 2.43, -5, 2.24, 0, 0, 1, 14, 4, 100
21:41:46, 3, 2195, 74, 0.2, 106, 14.6, 0.78, 2.59, -5, 2.39, 0, 0, 1, 14, 4, 100
21:41:46, 4, 2271, 74, 0.2, 104, 14.4, 0.82, 3.06, -4, 2.9, 0, 0, 1, 14, 5, 101
21:41:46, 5, 2219, 73, 0.2, 104, 14.5, 0.8, 3.33, -5, 3.22, 0, 0, 1, 14, 4, 100
21:41:46, 6, 2114, 70, 0.2, 106, 14.4, 0.83, 3.49, -4, 3.33, 0, 0, 1, 14, 4, 84
21:41:46, 7, 2064, 61, 0.2, 106, 14.4, 0.83, 3.22, -4, 3.22, 0, 0, 1, 13, 4, 84
21:41:46, 8, 2171, 45, 0.2, 103, 14.3, 0.85, 3.45, 0, 3.45, 0, 0, 1, 14, 4, 52
21:41:46, 9, 2136, 34, 0.2, 107, 14.3, 0.84, 3.96, 0, 3.96, 0, 0, 1, 14, 4, 36
21:41:46, 10, 2212, 22, 0.2, 104, 14.2, 0.87, 3.61, 0, 3.61, 0, 0, 1, 14, 4, 4
21:41:46, 11, 2229, 17, 0.2, 104, 14.2, 0.86, 3.88, 0, 3.88, 0, 0, 1, 14, 4, 4
21:41:47, 0, 2285, 18, 0.2, 104, 14.2, 0.86, 3.29, 0, 4, 0, 0, 1, 13, 5, 5
21:41:47, 1, 2322, 17, 0.2, 104, 14.3, 0.86, 3.88, 0, 3.88, 0, 0, 1, 14, 5, 5
21:41:47, 2, 2338, 17, 0.2, 104, 14.2, 0.86, 3.88, 0, 3.61, 0, 0, 1, 13, 5, 5
21:41:47, 3, 2405, 17, 0.2, 105, 14.3, 0.84, 3.1, 0, 3.1, 0, 0, 1, 14, 5, 5
21:41:47, 4, 2431, 17, 0.2, 108, 14.3, 0.86, 3.8, 0, 4, 0, 0, 1, 14, 5, 5
21:41:47, 5, 2468, 17, 0.2, 104, 14.3, 0.84, 3.33, 0, 3.33, 0, 0, 1, 14, 5, 5
21:41:47, 6, 2531, 17, 0.2, 107, 14.3, 0.86, 3.73, 0, 3.73, 0, 0, 1, 14, 5, 5
21:41:47, 7, 2546, 16, 0.2, 109, 14.4, 0.84, 3.96, 0, 3.96, 0, 0, 1, 13, 5, 5
21:41:47, 8, 2605, 17, 0.2, 107, 14.4, 0.83, 4.08, 0, 4.08, 0, 0, 1, 13, 5, 5
21:41:47, 9, 2634, 16, 0.2, 107, 14.4, 0.82, 3.92, 0, 4.08, 0, 0, 1, 14, 5, 5
21:41:47, 10, 2708, 16, 0.2, 104, 14.3, 0.84, 4.04, 0, 4.04, 0, 0, 1, 13, 6, 6
21:41:47, 11, 2754, 16, 0.2, 105, 14.4, 0.83, 4.04, 0, 3.76, 0, 0, 1, 14, 6, 6
21:41:48, 0, 2773, 16, 0.2, 104, 14.3, 0.84, 3.92, 0, 3.92, 0, 0, 1, 14, 6, 6
21:41:48, 1, 2827, 16, 0.2, 107, 14.4, 0.82, 3.57, 0, 3.57, 0, 0, 1, 14, 6, 6
21:41:48, 2, 2875, 16, 0.2, 105, 14.3, 0.84, 4.12, 0, 4.12, 0, 0, 1, 14, 6, 6
21:41:48, 3, 2930, 16, 0.2, 107, 14.2, 0.86, 4.08, 0, 4.08, 0, 0, 1, 13, 6, 6
21:41:48, 4, 2944, 16, 0.2, 103, 14.3, 0.85, 3.96, 0, 3.96, 0, 0, 1, 14, 6, 6
21:41:48, 5, 3032, 16, 0.2, 102, 14.2, 0.86, 4.12, 0, 4.12, 0, 0, 1, 14, 6, 6
21:41:48, 6, 3055, 16, 0.2, 102, 14.2, 0.86, 3.92, 0, 4.27, 0, 0, 1, 13, 6, 6
21:41:48, 7, 3114, 16, 0.2, 102, 14.2, 0.86, 4.27, 0, 4.27, 0, 0, 1, 14, 7, 7
21:41:48, 8, 3150, 16, 0.2, 103, 14.2, 0.87, 4.39, 0, 3.96, 0, 0, 1, 14, 7, 7
21:41:48, 9, 3190, 16, 0.2, 105, 14.2, 0.87, 4.12, 0, 4.12, 0, 0, 1, 13, 7, 7
21:41:48, 10, 3235, 16, 0.2, 102, 14.2, 0.86, 3.96, 0, 3.96, 0, 0, 1, 14, 7, 7
21:41:48, 11, 3273, 16, 0.2, 107, 14.2, 0.86, 4.47, 0, 4.47, 0, 0, 1, 14, 7, 7
21:41:48, 12, 3340, 16, 0.2, 104, 14.4, 0.83, 4.47, 0, 4.47, 0, 0, 1, 15, 7, 7
21:41:49, 0, 3376, 16, 0.2, 104, 14.2, 0.86, 4.39, 0, 4.39, 0, 0, 1, 14, 7, 7
21:41:49, 1, 3422, 16, 0.2, 109, 14.4, 0.82, 4.63, 0, 4.63, 0, 0, 1, 14, 7, 7
21:41:49, 2, 3465, 16, 0.2, 107, 14.3, 0.85, 4.67, 0, 4.08, 0, 0, 1, 13, 7, 7
21:41:49, 3, 3512, 16, 0.2, 107, 14.4, 0.82, 4.04, 1, 4.08, 0, -1, 1, 14, 8, 8
21:41:49, 4, 3559, 16, 0.2, 103, 14.4, 0.84, 4.12, 1, 4.71, 0, -1, 1, 13, 8, 8
21:41:49, 5, 3615, 16, 0.2, 105, 14.4, 0.81, 4.04, 1, 4.08, 0, -1, 1, 14, 8, 8
21:41:49, 6, 3631, 16, 0.2, 104, 14.4, 0.83, 4.47, 1, 4.51, 0, -1, 1, 14, 8, 8
21:41:49, 7, 3714, 16, 0.2, 104, 14.4, 0.82, 4.71, 1, 4.75, 0, -1, 1, 14, 8, 8
21:41:49, 8, 3728, 16, 0.2, 104, 14.4, 0.83, 4.94, 1, 4.98, 0, -1, 1, 13, 8, 8
21:41:49, 9, 3783, 16, 0.2, 103, 14.4, 0.82, 4.2, 1, 4.98, 0, -1, 1, 14, 8, 8
21:41:49, 10, 3810, 16, 0.2, 104, 14.4, 0.83, 5.02, 1, 4.98, 0, -1, 1, 14, 8, 8
21:41:49, 11, 3885, 16, 0.2, 106, 14.4, 0.83, 5.06, 1, 4.16, 0, -1, 1, 14, 8, 8
21:41:50, 0, 3919, 16, 0.2, 103, 14.3, 0.85, 4.2, 1, 4.24, 0, -1, 1, 14, 9, 9
21:41:50, 1, 3950, 16, 0.2, 108, 14.4, 0.82, 4.43, 1, 4.55, 0, -1, 1, 13, 9, 9
21:41:50, 2, 3978, 16, 0.2, 104, 14.3, 0.86, 4.31, 1, 4.35, 0, -1, 1, 13, 9, 9
21:41:50, 3, 4012, 16, 0.2, 107, 14.4, 0.83, 4.51, 1, 4.55, 0, -1, 1, 13, 9, 9
21:41:50, 4, 4062, 16, 0.2, 104, 14.3, 0.85, 5.18, 1, 4.98, 0, -1, 1, 14, 9, 9
21:41:50, 5, 4127, 16, 0.2, 101, 14.3, 0.85, 4.67, 1, 4.71, 0, -1, 1, 13, 9, 9
21:41:50, 6, 4184, 16, 0.2, 108, 14.3, 0.85, 5.1, 1, 4.67, 0, -1, 1, 14, 9, 9
21:41:50, 7, 4236, 16, 0.2, 101, 14.3, 0.84, 4.55, 1, 4.59, 0, -1, 1, 13, 9, 9
21:41:50, 8, 4243, 16, 0.2, 105, 14.3, 0.85, 4.51, 1, 4.98, 0, -1, 1, 14, 9, 9
21:41:50, 9, 4253, 16, 0.2, 103, 14.4, 0.83, 5.18, 1, 4.98, 0, -2, 1, 14, 10, 10
21:41:50, 10, 4314, 16, 0.2, 105, 14.3, 0.85, 4.94, 1, 4.98, 0, -2, 1, 13, 10, 10
21:41:50, 11, 4382, 16, 0.2, 104, 14.4, 0.83, 5.14, 1, 4.98, 0, -2, 1, 14, 10, 10
21:41:50, 12, 4447, 16, 0.2, 102, 14.4, 0.81, 5.1, 1, 4.98, 0, -2, 1, 14, 10, 10
21:41:51, 0, 4467, 16, 0.2, 106, 14.4, 0.82, 4.78, 1, 4.94, 0, -2, 1, 13, 10, 10
21:41:51, 1, 4525, 16, 0.2, 107, 14.4, 0.82, 5.06, 1, 4.98, 0, -2, 1, 14, 10, 10
21:41:51, 2, 4525, 16, 0.2, 109, 14.4, 0.81, 4.51, 1, 4.55, 0, -2, 1, 14, 10, 10
21:41:51, 3, 4617, 16, 0.2, 111, 14.5, 0.8, 5.1, 1, 4.98, 0, -2, 1, 15, 10, 10
21:41:51, 4, 4617, 16, 0.2, 105, 14.4, 0.82, 5.22, 1, 4.98, 0, -2, 1, 14, 10, 10
21:41:51, 5, 4689, 16, 0.2, 103, 14.4, 0.84, 5.22, 1, 4.98, 0, -2, 1, 14, 10, 10
21:41:51, 6, 4701, 16, 0.2, 104, 14.4, 0.84, 5.29, 2, 4.98, 0, -2, 1, 13, 11, 11
21:41:51, 7, 4804, 16, 0.2, 107, 14.3, 0.84, 4.82, 2, 4.9, 0, -2, 1, 13, 11, 11
21:41:51, 8, 4804, 16, 0.2, 103, 14.2, 0.86, 4.86, 2, 4.94, 0, -2, 1, 13, 11, 11
21:41:51, 9, 4869, 16, 0.2, 102, 14.3, 0.86, 5.1, 2, 4.98, 0, -2, 1, 14, 11, 11
21:41:51, 10, 4894, 16, 0.2, 108, 14.3, 0.86, 5.14, 2, 4.98, 0, -2, 1, 14, 11, 11
21:41:52, 0, 4956, 16, 0.2, 111, 14.4, 0.84, 4.9, 2, 4.98, 0, -2, 1, 14, 11, 11
21:41:52, 1, 5005, 16, 0.2, 107, 14.3, 0.84, 4.98, 2, 4.98, 0, -2, 1, 13, 11, 11
21:41:52, 2, 4979, 16, 0.2, 110, 14.3, 0.84, 4.94, 2, 4.98, 0, -2, 1, 14, 11, 11
21:41:52, 3, 5044, 16, 0.2, 103, 14.4, 0.83, 4.94, 2, 4.98, 0, -2, 1, 13, 11, 11
21:41:52, 4, 5043, 16, 0.2, 101, 14.4, 0.82, 5.06, 3, 4.98, 0, -3, 1, 13, 12, 12
21:41:52, 5, 5143, 16, 0.2, 106, 14.4, 0.82, 5.02, 3, 4.98, 0, -3, 1, 14, 12, 12
21:41:52, 6, 5171, 16, 0.2, 108, 14.3, 0.84, 5.25, 3, 4.98, 0, -3, 1, 14, 12, 12
21:41:52, 7, 5197, 16, 0.2, 107, 14.3, 0.85, 5.25, 3, 4.98, 0, -3, 1, 13, 12, 12
21:41:52, 8, 5243, 16, 0.2, 101, 14.2, 0.86, 5.06, 3, 4.98, 0, -3, 1, 14, 12, 12
21:41:52, 9, 5261, 16, 0.2, 106, 14.3, 0.86, 5.14, 3, 4.98, 0, -3, 1, 14, 12, 12
21:41:52, 10, 5244, 16, 0.2, 113, 14.2, 0.87, 5.22, 3, 4.98, 0, -3, 1, 15, 12, 12
21:41:53, 0, 5301, 16, 0.2, 102, 14.4, 0.84, 5.22, 3, 4.98, 0, -3, 1, 13, 12, 12
21:41:53, 1, 5356, 16, 0.2, 102, 14.3, 0.84, 5.25, 3, 4.98, 0, -3, 1, 13, 12, 12
21:41:53, 2, 5365, 16, 0.2, 104, 14.3, 0.85, 5.37, 3, 4.98, 0, -3, 1, 13, 12, 12
21:41:53, 3, 5410, 17, 0.2, 107, 14.3, 0.86, 5.37, 3, 4.98, 0, -3, 1, 14, 12, 12
21:41:53, 4, 5430, 16, 0.2, 103, 14.2, 0.87, 5.06, 3, 4.98, 0, -3, 1, 14, 12, 12
21:41:53, 5, 5469, 16, 0.2, 107, 14.3, 0.86, 5.45, 4, 4.98, 0, -3, 1, 13, 13, 13
21:41:53, 6, 5494, 16, 0.2, 103, 14.3, 0.85, 4.98, 3, 4.98, 0, -3, 1, 14, 12, 12
21:41:53, 7, 5586, 16, 0.2, 104, 14.3, 0.84, 5.37, 4, 4.98, 0, -3, 1, 13, 13, 13
21:41:53, 8, 5617, 16, 0.2, 105, 14.4, 0.83, 5.49, 4, 4.98, 0, -3, 1, 14, 13, 13
21:41:53, 9, 5571, 16, 0.2, 107, 14.4, 0.83, 5.14, 4, 4.98, 0, -3, 1, 13, 13, 13
21:41:53, 10, 5600, 16, 0.2, 103, 14.4, 0.83, 5.18, 4, 4.98, 0, -3, 1, 14, 13, 13
21:41:53, 11, 5659, 16, 0.2, 104, 14.3, 0.85, 5.49, 4, 4.98, 0, -3, 1, 13, 13, 13
21:41:54, 0, 5689, 16, 0.2, 105, 14.4, 0.84, 5.33, 4, 4.98, 0, -3, 1, 14, 13, 13
21:41:54, 1, 5754, 17, 0.2, 104, 14.4, 0.82, 5.18, 4, 4.98, 0, -3, 1, 14, 13, 13
21:41:54, 2, 5781, 16, 0.2, 104, 14.4, 0.82, 5.25, 4, 4.98, 0, -3, 1, 13, 13, 13
21:41:54, 3, 5777, 16, 0.2, 101, 14.4, 0.82, 5.45, 4, 4.98, 0, -3, 1, 14, 13, 13
21:41:54, 4, 5844, 16, 0.2, 104, 14.4, 0.82, 5.41, 4, 4.98, 0, -3, 1, 13, 13, 13
21:41:54, 5, 5826, 16, 0.2, 107, 14.4, 0.84, 5.45, 4, 4.98, 0, -3, 1, 13, 13, 13
21:41:54, 6, 5858, 16, 0.2, 102, 14.4, 0.82, 5.33, 4, 4.98, 0, -3, 1, 13, 14, 14
21:41:54, 7, 5909, 16, 0.2, 107, 14.4, 0.82, 5.41, 4, 4.98, 0, -3, 1, 13, 14, 14
21:41:54, 8, 5913, 16, 0.2, 105, 14.4, 0.82, 5.33, 4, 4.98, 0, -3, 1, 13, 14, 14
21:41:54, 9, 5961, 18, 0.2, 108, 14.4, 0.83, 5.45, 4, 4.98, 0, -3, 1, 14, 14, 14
21:41:54, 10, 6023, 32, 0.2, 107, 14.3, 0.84, 5.45, 5, 4.98, 0, -3, 1, 14, 14, 30
21:41:54, 11, 6018, 75, 0.2, 103, 14.3, 0.84, 4.55, 0, 4.51, 0, 0, 1, 13, 14, 94
21:41:55, 0, 5720, 94, 0.2, 106, 14.6, 0.7, 2.35, 0, 2.35, 0, 0, 1, 14, 13, 125
21:41:55, 1, 5489, 93, 0.2, 103, 14.6, 0.63, 2.94, 0, 2.98, 0, 0, 1, 13, 12, 124
21:41:55, 2, 5375, 94, 0.2, 106, 14.6, 0.62, 1.96, 0, 1.96, 0, 0, 1, 14, 12, 124
21:41:55, 3, 5161, 93, 0.2, 108, 14.6, 0.63, 1.1, 0, 1.1, 0, 0, 1, 13, 12, 124
21:41:55, 4, 5161, 94, 0.2, 100, 14.6, 0.63, 0.82, 0, 0.82, 0, 0, 1, 14, 12, 124
21:41:55, 5, 5005, 94, 0.2, 103, 14.6, 0.62, 1.1, -1, 1.06, 0, 0,
NICO
Post by NICO »
ok here is neetronics number call them up 1 905 602 1949, or email them.
Enough bickering.
NICO, I am inclined to believe Doug over you. I have used the perfect power, it most certainly can data log.
Neetronics may have tweaked things in the ECU, but that doesn't matter, the sensor only has a certain range.
douglas vincent
Nico.
There is no "hate" as you call it.
Its simply you offer NO proof other than hear say. Simple as that. I believe you make serious power. I recieved an email from neetrontics backing that up to a point, but until you actually back up this MAF stuff, NO ONE believes you.
Why?
Because multiple people have tried removing the plate and NO ONE has replicated what you are claiming. If you keep this up, you are as bad as the Korean Clone King!
We want you to be right, but you are not, according to our results.
Peace.
NICO
Post by NICO »
lol douglas vincent, it works and its all most dyno day i will get papaers to show.
NICO I WRX U wrote:lol douglas vincent, it works and its all most dyno day i will get papaers to show.
What you need to do is log the MAF sensor voltage as well.
