Have a good chance to get the whole rear suspension parts with the 4.444LSD diff., rear crossmember, all the link and arms.
since my car has seizzs bushing on all the link and arms, it will be the good chance to do the swap, but since the parts comes with the 4.444 Ver4-Ver6 rear diff w/LSD, will it bolt on to the 92 Legacy turbo?
Anyone knows?
Please help!
Ben
Will 4.444LSD diff fits to 92 Legacy turbo 5spd?
92 Legacy turbo with EJ20G engine swap \(^0^)/
Unless you've got a tranny with a 4.444 front ratio you won't be able to directly bolt it in, since front and rear ratios need to match.
It may be possible to swap the LSD parts out of that differential and into your current one, though; ciper is the best source for info on that (I'd start by searching for his posts on the subject).
I don't know about the other parts, but I would guess they would fit. The only thing that varied a lot in the rear tended to be the type of axles and how they mated with the differential.
