Moderators: Helpinators , Moderators
Splinter
Posts: 3058 Joined: Tue Aug 02, 2005 11:12 pm
Post
by Splinter » Sun Aug 20, 2006 5:48 pm
So I just got my car back together, now with WRX struts, and Ive noticed a harsh grinding noise when going around hard right hand corners.
We painted the inside rim of the tire, and its not coming from that.
Any ideas?
Yukonart
Cradle Robber
Posts: 2655 Joined: Wed Aug 13, 2003 10:45 am
Post
by Yukonart » Sun Aug 20, 2006 6:12 pm
Did you remember to get the washer(s) in the right place on the strut assembly? I forgot the placement of one when I was doing a friend's suspension last year and it drove me nuts until I took the damn assembly apart and noticed a washer in the wrong place.
1994 & 2005 Legacy GT Wagons
Splinter
Post
by Splinter » Sun Aug 20, 2006 6:24 pm
The strut assembly wasnt disassembled. It was unbolted from the WRX and bolted onto my legacy
Imprezive
Posts: 1428 Joined: Wed Jun 22, 2005 4:07 am
Post
by Imprezive » Sun Aug 20, 2006 6:44 pm
check powersteering fluid
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
Splinter
Post
by Splinter » Sun Aug 20, 2006 6:45 pm
Its coming from the drivers side front wheel area, for sure.
And I only get it when the car is moving
greg donovan
Posts: 1947 Joined: Fri Oct 03, 2003 6:22 pm
Post
by greg donovan » Sun Aug 20, 2006 8:47 pm
have you checked the wheel bearings?
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
Splinter
Post
by Splinter » Sun Aug 20, 2006 8:51 pm
No... but everything was peachy before I changed struts
Imprezive
Post
by Imprezive » Sun Aug 20, 2006 9:35 pm
jack the front end up and crank the wheel to lock and see if anything rubs, then turn the wheel to the opposite lock and do it again. Maybe that might help.
check the tire sidewall to see if its rubbing on the inside fender lip, check that lip too, if there is any rubber shavings or anything like that.
1988 4Runner RIP
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
Splinter
Post
by Splinter » Sun Aug 20, 2006 10:50 pm
Yea Ive tried that... its driving me nuts
I need to get it running on a hoist
Splinter
Post
by Splinter » Mon Aug 21, 2006 8:40 am
Hmm... turns out its not just full lock.
Partial rights at speed produce the same sound
Im wondering if it could just be bad alignment
Imprezive
Post
by Imprezive » Mon Aug 21, 2006 6:46 pm
Your camber might be off because of the new struts, and the fact that it occurs at speed makes me think it's your wheels rubbing the fender lip, in my brothers legacy it makes a scraping noise that you wouldnt really expect from a tire rubbing on a fender. But I guess this isnt the case???
What kind of rims/tires do you have?
What springs are on there? wrx springs?
1988 4Runner RIP
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
Splinter
Post
by Splinter » Mon Aug 21, 2006 8:36 pm
Ive got stock rims and stock dimension tires (BFG's)
The entire strut assembly is WRX, springs and tophats.
Imprezive
Post
by Imprezive » Tue Aug 29, 2006 7:01 pm
Ummm, totally forgot about this thread... Did you finally figure it out?
1988 4Runner RIP
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
Splinter
Post
by Splinter » Tue Aug 29, 2006 9:07 pm
No, but it hugely improved after an alignment. The guy said the camber on that wheel was waaaay off.
I know Ive got torn boots all over that side of the car too. Im hoping to get it up on a hoist in a week or two and replace most of them
