If you are talking about Marc's remarks about a 7.5:1 CR on his car I think he is correct, for his vehicle. But keep in mind his car has EJ25 DOHC heads and he has custom pistons. He chose his CR...ciper wrote:Somewhere in this thread it mentions that the compression ratio for ej20 heads on an ej22t is 7.5:1 . I think that is wrong.
read this thread http://bbs.legacycentral.org/viewtopic.php?t=14511
Notes on the Ej22T!! - More info added!!
Matt Monson
- quasi-mod-o
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
Re: Notes on the Ej22T!! - More info added!!
Who is this guy. I want a damn ride.My name is Mark Ramirez, not Alan. PDM turbos has pictures of my engine bay on their website, although the text description of what is actually in my car is very inaccurate. 90% of the work on my car has been done by me in my own shop. PDM has been a great help in a lot of the work (i.e. welding and tube bending), but as far
98 LGT
so, has anyone here tried phase I dohc heads on a turbo legacy block?
What other parts would I need to make this work? Obviously new timing belt, intake manifold, etc...internally though are new rods/crank neccesary?
dirt-covered 91 SS prorally
pat richard roll cage, DMS 50mm, stickers...
SOLD :(
99 impreza RS
ver. 7 sti swap, ver. 6 RA suspension, JDM bodywork, rotated GT28rs
SOLD :(
99 impreza RS
Matt Monson
- quasi-mod-o
He asking about phase I EJ25 heads. Different market. But it is a little known fact around here that USDM phase I DOHC EJ25 heads use the same cores as 1998 JDM EJ20K heads.EJ20TMAN wrote:Yeah heaps of ppl have P1 heads and a turbo block, its called a EJ20G, my car has one
Aspect,
You need to re-read this from the first post. Xehpyr uses those exact heads and gives you most of the detail required for this set up.
One last thing that I have mentioned elsewhere, but want to put in the sticky. I have empirically verified that the EJ22T block and the 22b blocks are abolutely NOT the same. Not just the internals, but the cores are totally different. I chatted with a UK fellow who owns a 22B and has rebuilt his own engine. He verified for me that the 22B is a phase II block with the thrust bearing moved to the end, not centered like th EJ22T block. Furthermore, it was cast without the oil squirters. They are not capped, they just plain don't exist on the cast. And lastly, it is not an overbored EJ20. His block says EJ22 right on it. Thus endeth the lesson...
Suby Hai!
Suby Hai!
musketeerracing
But...but...Phase 1 crank, rods, heads on 22t unresolved
Tried not to post this but I'm still getting conflicting information after trolling all this thread, any related thread I can find, and the "library" section on the main page. So I'll try to ask the questions that have been posted before but answered with other questions:
1. Is Phase 1 2.5L crank a direct bolt-in in the 91-94 USDM EJ22t? I think this is what has been said, just confirming here.
2. Is it necessary to use the Phase 1 rods as well? I presume so, but I don't see any obvious reasons the EJ22t rods might not work.
3. (here's an area where posts differ every time): Are the Phase 1 2.5L DOHC heads a bolt-on for the 91-94 USDM EJ22t? The posting in the "library" section says only Phase 2 2.5L DOHC heads will work, but intelligently details all the reasons not to use them anyway. Now in thie thread people are talking about the Phase 1 heads as bolt-on. Are they? And do they suffer all the same disadvantages as the Phase 2 heads, namely a larger bore, wrong cams for turbocharging, and slightly misaligned coolant passages?
4. When is the Phase 1/Phase 2 threshold? Some people say when it went DOHC to SOHC(?!). Some say when it went interference with a reshaped piston crown. Some say when the thrust bearing moved from the center of the crank to the end (or vice-versa?). Did these all happen at the same time? I don't think so. I _think_ the dates are 1997, 1997, and 1999 respectively. But then I see that the premium fuel required on the 1996 2.5L Outback was dropped for 1997. Um, does this imply a drop in compression? Huh? 2.5L got 10 more horses at the same time. So....confused.
And here's the why Im interested: one of my (now three) EJ22t just spun a bearing. So I'm rebuilding, and I have access to a NA 2.5L out of a 1997 Outback. Should I, taking the received wisdom of this board, grab the 2.5L crank and rods (although apparently inferior material(?), but for a 2.35L displacement)? And to my knowledge, a never-answered, important question: will the stock 91-94 USDM EJ22t pistons work with this setup, both in terms of head interference and a sensible compresison ratio?
Here's the only wisdom I can offer, from experience with stroker motors: even a little displacement, especially in the stroke, matters, and especially at high boost. Torque goes up a lot.
Sorry, I thought those questions would be short...
ACP
ACP
ACP
www.musketeerracing.com
1991 Legacy SS 5MT Rally car (sold)
1993 Legacy SS 5MT Street car (selling)
1997 Lancer Evo IV RS Rally car (sold)
2006 Lancer Evo IX RS Rally car
2009 Lancer Evo X RS Rally car
1989 240SX SR20 Drift car
Please refer to this thread. http://bbs.legacycentral.org/viewtopic. ... ej22t+dohc
I think it makes the article in the library obsolete.
If you have any questions on the head swap, please post it in that thread.
1997 White BG Ltd 5MT, EJ22T with Wiescos, EJ20R Heads, Two large dents R.I.P
1995 Impreza EJ22T DOHC Hydra EMS, 20g, EWG, 3in APS TBE, AWIC
musketeerracing
OK - that thread deals with the heads. Thanks. Now how about the crank, rod, piston, and "phase" questions?
Thanks for pointing me to the thread though - deals with the heads well. Although even there "Matt" is saying you need Phase 2 head - obviously not, then...
ACp
ACp
ACP
In 99(00 for the legacy) we saw the 2.2 and the 2.5 change to Phase II.
On both the 2.2 and 2.5 the Phase II changes were as follows:
1. The engine and the transmission are fastened with 6 bolts
and 2 studs.
2. The thrust bearing has been moved to the number 5 position.
3. Oil groove in the number 1 and 3 have been changed to
supply additional lubrication to the crank journal.
And Yes thats when the 2.5 went to SOHC.
In 97 both the 2.2 and 2.5 saw some "Enhancements"
Both got new pistons which put comp to 9.7 to 1
The pistons were moly coated and piston clearances were reduced by increasing the diameter of the piston.
and 2 studs.
musketeerracing
Awesome! Now I get it. Thanks.
Remaining questions:
Does the Phase 1 2.5L crank swap require 2.5L rods? (It must, no?)
Does it require different pistons, or can the EJ22t pistons be used?
With the EJ22t sohc heads and pistons nd headgasket, and the 2.5L crank and rods, anyone know the compression ratio?
Thanks again,
ACP
Thanks again,
ACP
ACP
greg donovan
i believe JB Niday has a 2.35 motor in his impreza you should PM him over on the RA site. maybe he would be able to help you out.musketeerracing wrote:Awesome! Now I get it. Thanks.
Thanks again,
ACP
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
00 Impreza RS sedan
Yes you need to run premium.
