help!! my motor mounts arnt lining up
95LegacyLsi
Post by 95LegacyLsi »
OK I begin this tale by trying to replace my oil pan gasket... and in order to reach those last 4 bolts in the back it was nessisary to raise the engine up a few inches, but now when i went to put it back down i am at least the bolt's diameter off.
basically the body and front subframe hole is behind the motor mount now....... is there anyway i can rock the car forward or back to help line it up?
has anyone run into this problem before?
or should i just take off the motor mounts, attach to the body and then try and line up the engine???
HELP ME
SOS
AHHHHHHH!
Jack up engine/transmission and push the bolts in with a large screwdriver or something to align holes while lowering the jack.
Yeah, you'll just have to man-handle it.
Post by entirelyturbo »
When I did my motor mounts, I used a rope to pull on the bolt in order to align it with the hole in the crossmember.
Don't feel bad, the mass-production of parts, especially rubber ones, ensures that some of the parts will come out a little deformed and have to be worked into place by the end user.
It won't have any effect on the mount's performance.
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
95LegacyLsi
good advice
i think i asked for this by trying to shadetree mechanic this one. I think i may have found something to physically pull the engine back in place, maybe some tie straps and some light will fix this
this is the last time i try this on the ground.
Thanks all
