Before shot (11.4" WRX brakes, 17" Rota Formel wheels):
WRX rotor on the left, LGT on the right:
WRX rotor on top, LGT on the bottom:
The LGT rotor is much thicker:
LGT caliper is also beefier:
Installed, the difference is noticeable:
From afar:
I bled 24-30oz of fluid through, over a full, large bottle. The feel isn't much different than the WRX, probably because the pad size is similar and the caliper isn't much larger. I'm hoping that the feel will improve with a bit more use and conditioning, but I'm satisfied that it's as good as the old setup.
I am pleased at how much better the new rotors fill the wheels and that I have a much larger heat capacity in the rotors, which this heavy car needs.
