91 legacy turbo awd autoej2.2`
albert gotch
I bought this car with a bad engine found a very good used n/a from a 1994 legacy tried to find out before I started to see if this will work got no replys so I installed engineall the sensors seemed to hook up & looked the same hooked them up I had upuged the turbo sensors & got the engine started didn't run well & got CEL hooked them up it seemed to run better but not right when I start it idles 1800 to 2000 rpm after a couple minutes it will slow down but then start to lope probably because its running rich I tried a used ECU from a 94 legacy n/a 5speed M/T now it will not start My question is would an ECU from a 91 legacy n/amake it all better? the codes I get are 21-31-45 but they do not set the CEL if I clear codes run the engine the same codes are back HELP ![/list]
albert gotch
91 legacy 2.2
yes it will be for sale if I don't find soon how toget to run right The car has only 70K on meter engine has only 16K it sat in bone yard for 10yrsthe car was totaled in 1996but like I said I would like to get it going& use it myself Al
