Supercharger.........
oook.
so i'm new and i've just been reading over a few of the topics on here.
i have a 93 legacy N/A and i was just wondering if i could put a s/c on my car.
if so....
what brand?
and how do i mount it?
if so....
what brand?
personaly, id rather get a centrifugal s/c
like a Paxton or Vortech or Procharger, theres several other but those seem to be the best, to find the right one youd go to the website, they usualy have a thing that shows which s/c is best for your car, it goes by the power output, the less power the smaller s/c and read reviews about them to see who you think is better
you want a self contained s/c, so that you dont have to tap holes in your oil pan and run lines up, that makes alot of complications
you should think about doing the 2.5L head swap for better fuel and air flow, youd also need some way to tune it so think about piggy back or stand alone ECUs
1990 Legacy LS, 4EAT
this is the Eaton M62 with a clutch, its a roots-type blower
http://club.corrado.free.fr/prepa/eaton/M62.jpg
this is a centrifugal supercharger, think of it as a belt driven turbo
http://www.carcraft.com/techarticles/p1 ... _small.jpg
they are much more compact, a little easier to mount most of the time since they are smaller, much easier to run intake piping since its made to run pipe and not sit on a manifold, you could use the intercooler and hood off a turbo legacy
roots-types are the most cost-efficient but the least efficient at making power because it has no internal compression, its external compression also creates more heat than that of a centrifugal
so youll get more power from 5psi in a centrifugal than 5psi on a roots, but if you want the most youd get a twin-screw s/c
the roots is also not a compressor, it is a "air delivery system" hence the name "blower"
ooo burnnnn
if you didnt look at it you realy should, its a very interesting setup he has, a centrifugal would be mounted sorta the same manner as that one since that looks like the most simple way to do it
and youd need a new fully tunable ecu or find some way to tune your current one, theres a home-made thing that you can do but im not sure if it just looks at the data or you can actualy tune
Except for the fact it blew up because I was running it un-intercooled, I was hitting 15 psi supercharged with the DOHC heads. Of course I was getting that because I WASNT going through the intercooler.
#250 for supercharger,
$250 min for intake and exhaust plumbing from supercharger
$100 min for bigger injectors
$300 min for intercooler and piping
$250 min for new clutch, NA dont hold
$470 for SMT6 (piggyback computer)
$? or ability to do all work yourself.
It adds up.
It adds up.
money is the only reason i cant do anything to my car at the moment, that and id have to do it over a vaction period were i wouldnt need it as much
yeah, $250 is a very rock bottom minimum for a s/c, and you also get what you paid for, for the most part, you buy a $250 s/c it will run like a $250s/c, for that price its most certainly a used one, thats also only small roots blowers
a centrifugal is usualy $1,400-$3,000. and a twin screw is even more, but since your not wanting road ripping power a roots should suit you well as long as you do things like intercool it, unlike some people
"I just want horsepower to race Hondas"
That just raises red Flags to me, right there. Why would you lower yourself to their level by racing them? Do People know nothing about Subarus? They're not made for drag racing! They are AWD cars...
*sigh*
*sigh*
185,000 miles
185,000 miles
Spend the time engineering your own front-mount intercooler setup and piping... spend some time measuring with your front fascia off, get some dimensions and tentative ideas for what to look for, spend some time watching and searching eBay for an appropriate 'cooler, then spend some time behind the counter at a Napa or Pep Boys, looking at the large truck preformed radiator hose, and then get the rest of the bends, straight sections, and couplers bent and cut from exhaust pipe at any muffler / exhaust shop. Yoo can doo eet.
You'd spend mad money paying a professional to fab up some intercooler piping for your car, and for the install.
-Chris
91SS 4EAT stock
91SS 5MT awaiting engine rebuild and VF36...
92SS 4EAT - RIP
94SS 5MT4.11+rLSD 289k km: RobTune550,TD05-16g @ 18psi,FMIC,3"TBE,Forester lift
91SS 4EAT stock
92SS 4EAT - RIP
yeah getting someone to do that for you would be an insane amount of money, btw how much are you wanting to spend on this?
theres no rallies around here (with in 200miles) and the only tracks in 5 hours driving distance are a series of drag strips, so i wouldnt realy ever race mine, just run it through a corn field, my comp would only be trucks, in town the only comp is hondas, stangs and this one fugly looking eclipse
but i have yet to get a properly working transmission so that wont be anytime soon (if ever)
Check into the front mount from a diesel GMC/Chevy/Isuzu box truck. It looks like a good fit on our cars. I'm hoping the truck at work dies and we get permission to scrap it. I also want the roof vent.
That's the one I have on my '94, intercooler from an Izuzu NPR boxtruck, from eBay for like $75 or so shipped. Had to cut some holes in the sheet metal for the inlet / outlet and sawzall the top of the bumper beam off. The IC sits on the bottom of my bumper beam and is mounted by some bent aluminum strips at the top.
-Chris
91SS 4EAT stock
92SS 4EAT - RIP
91SS 4EAT stock
92SS 4EAT - RIP
