n00b header question
kel
Post by kel »
im buying my first subie real soon, 96 leggy LSi sedan
Right so my question is
Will This
fit on this
2.5l NA now i know thats the RS header but will it fit
scuzzy
Re: n00b question ...heh
Post by scuzzy »
kel wrote:im buying my first subie real soon, 96 leggy LSi sedan
Will This
fit on this
not without crossmember modification.
#82 M4 TRSCCA Rallycross
BAC5.2
Post by BAC5.2 »
If that's a 96, then it's not an EJ25...
But yes, it will fit. I think the EJ22 in 96 was dual port...
Look at your current header. I think 95 was still dual header ports. 96 was the first year for single port headers.
If that's the case, those won't work. You'll need headers for single port exhaust heads. Borla does make some though.
DLC
Post by DLC »
Correct me if I'm wrong, but I've heard that all Legacy EJ22s were dual port. If so, then you're fine.
Legacy Central
BAC5.2
Post by BAC5.2 »
Nah Dave, some of the EJ22's were single-port.
My 95-L was dual port.
I think Joshinator is right, 96 and 97 (and maybe 98?) had the single port heads on the EJ22 equipped models.
epike7915
Post by epike7915 »
Not to hijack a post but I have the same type question. Will the header off of a 97-01 Impreza RS work on my 97 Legacy GT 2.5 DOHC?
Thanks,
Eric
Eric P.
"My HERD"
97 Subaru Legacy GT 5 spd AWD (Driver)
91 "Wide White One" Zook
87 Buick Regal T-Type
87 Ford Mustang-351W (For Sale)
89 Ford F-350 Crew Cab Hauler "The Battle Axe!"
BAC5.2
Post by BAC5.2 »
It probably will.
spdracr
Post by spdracr »
Just need a quick yes/no answer..
Ok, so on my 92 n/a Legacy L it should have duel ports right? so any duel port header should bolt up.
spdracr wrote:Just need a quick yes/no answer..
Yes, your 92 has dual port heads. Any dual port header will fit the heads, however all the headers are designed to fit the newer cars which have different mid-pipe sections. So the header will not mate up to your mid-pipe. You'll need to get something custom done there.
spdracr
Post by spdracr »
hmm, custom exhaust in my future i'm thinking. wonder if its worth it.. anyone running headers on their 2.2l wanna chip in?
jamal
Vendor
Vendor
Post by jamal »
I'm shopping right now. I think I've decided on either the OBX EL header or the Borla. Borla has the best sound, OBX might have better gains. All I hear about Borla is that they sound awesome but crack. It is apparantly fixed on the new ones but I'm still a bit iffy. The EL will change the exhaust note a bit but the clips I've heard still sounded like a Subaru.
