speedo issues
92whitelegacy
speedo issues
Post by 92whitelegacy »
So yea im driving along and my speedo goes dead and the miles stop working im like WTF PISSED. anyways i replaced the speedo cable, and it didnt fix the problem so any other ideas how to fix this?
92 ss 275k+mi, kartboy shifter/bushings, gauges. VRG3 FCD II, NGK I'4s, TDO5-16G 4" dp CAT-less 3"tbe 4.11 gears.
Imprezive
Post by Imprezive »
It may have just slipped out of the Gauge cluster, those things are a bitch to get in and out. You should also check you installed the new one correctly on both sides.
like i said, its a bitch...
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
Is your legacy an auto? If so, the speedo cable base piece probably needs to be replaced. It's relatively common
http://www.main.experiencetherave.com:8 ... lebase.jpg
Bheinen74
Post by Bheinen74 »
Check the connection of the guage cluster and speedo cable first, make sure it is in fact good contact into the guage assembly.
check the base piece as listed. If those are both good......
jack up the car all 4 wheels off ground. unscrew/disconnect speedo cable at tranny, careful not to loose the rubber washer and the metal washer, sometimes stays in tranny. find a flat tipscrewdriver to fit slot where speedo cable goes into tranny.
start car, put in drive while all 4 wheels off ground. Take the slotted screwdriver and put into slot of tranny, see if the screwdriver is turning or if it turns, then stops. If it turns, your okay inside tranny. If it does not turn, or turns one revolution then acts as it is stripped, then see this link, you have bad speedo drive and speedo driven gears inside the tranny. easy fix, cheap parts, labor is a BITCH.
http://new.photos.yahoo.com/bheinen/alb ... 4010269/69
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
