are N/A steering racks=Turbo Steering racks
Bheinen74
Post by Bheinen74 »
are the steering racks exactly identical between NA and Turbo cars?
My turbo rack is needing replaced, and I have a lead on a good NA. thanks in advance.
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
Bheinen74
Post by Bheinen74 »
anyone know? bump
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
TDGKORN
Post by TDGKORN »
Not sure if they are exactly the same, but I have a 92na rackon my 92 turbo (works great). I do know the lines from the pump to the rack are a little different, but they will fit (I also have those from a 94 na on my car).
92 legacy ss 4eat
DLC
Post by DLC »
Turbos have speed-sensitive steering to some degree, so unless some NA model also had this, they'd be different in that regard. Otherwise they should fit fine, as in TDGKORN's example.
Legacy Central
Dave,
How are the turbo racks speed sensitive?
There's no additional wiring that I'm aware of?
DLC
Post by DLC »
That's a damned good question. I've read it in a few places, but I don't know if it's true or how it'd work without extra bits.
Legacy Central
scottzg
Post by scottzg »
i thought it was that all leggy racks were rpm sensitive
Post by entirelyturbo »
Part number is the same for NA and Turbo racks. The only different number is for postal wagons, for obvious reasons.
*Formerly DerFahrer*
