Anyone else heard this? Any details, was it a TSB or anything like that? My Legacy has 124k miles on it now
MT main bearings...
- quasi-mod-o
MT main bearings...
I've heard from several sources now that the main bearings in the 90-91 Legacy MT's are crap, destined to fail at an estimated 120k miles...
LaureltheQueen
- Spelling Nazi
your legacy is a baby.....I've got 174k and no issues of bottom end engine failure that I have seen......
- quasi-mod-o
Josh, it's the tranny main bearings that I'm referring to, hence posting this in the Drivetrain forum
I think someone over on the USMB made mention of it, as well as some other source.
I have absolutely no internal engine problems, nor tranny problems, I was just a little concerned about hearing this...
my bad.....
When I picked up my 90 Wagon it had about 170K on it and the guy knew it needed a clutch, so I gave him $200 for it and dropped in a clutch. When I had the tranny out I noticed that the main shaft moved up-down, side t o side alot, when I put it back together I found out that it popped out of 5th gear. I drove it for a month like this befor the tranny finnally made really bad noises and lost 1st, 3rd, and 5th gear. I took it apart to find out it had a trashed main bearing. Moral of the story is: If it starts popping out of 5th your probly losing the main bearing.
92 SVX 6 speed, 165 shot NOS, Koni GC
91 Legacy S.S. FMIC, TD04 (so what?)
90 Legacy wagon (Beater)
92 Loyal monster wagon (EJ22) and 30" tires.
78 BRAT (EJ22T comming)
I blow s@#t up.
I blow s@#t up.
