hi every one. ive got a 92 ss and im trying to figer out how to pull the codes from the ecu cause the engine light comes. it almost comes on every time after i floor the car. its starting to make me not want to drive it untill its fixed.
any help is greatly apresiated.
engine light after i floor it.
Last edited by 92ss satinsvoice on Wed Oct 11, 2006 9:44 pm, edited 1 time in total.
search on how to pull codes, and how to reset ECU.
Probably just the knock sensor, and if you need a new one they run about 50 from the discount subaru dealers.
Could be the MAF is a little dirty and you can clean that with some brake cleaner but you need to be careful and not touch the wires on the sensor.
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
thats because its in the library on the main page found here along with lots of other usefull information. Also check out the stuff you need to know section of the forum, there are many threads full of info such as service manuals, wirring diagrams, etc. Hope that helps and welcome to the forum.
93 SS 5MT - TD05H-16G, 06 TMIC, Walbro, Zeitronix WB-02 - Scrapped too much rust
91 SS AT
97 Outback - Prodrive quick rack, DMS 40
91 SS AT
