Seems my car came with a jack, but not the handle. Sure, I could use the short screw driver that came with it, but thats a pain in the butt. Whats the jack handle thing look like?
I've already been to NAPA and a local junk yard, but neither had one.
Whats the jack's handle look like?
'11 WRX Limited
'94 TW | R.I.P.
Hook, 12 inches of shaft, 90 degree bend, 6 inches of shaft, 90 degree bend to make the final 4 inches of shaft parallel with the long shaft.
Or, you could lift up the carpet in the trunk and look in the multi-box. (I assume you have a sedan) Molded into the plastic box there's a spot where the handle sits/snaps into. That's the shape you need. Hell, you might even find it there if you haven't looked there before.
