FS: turbo for custom applications GM-1
MRtuningCO
Post by MRtuningCO »
it is nearly brand new IHI/borgwarner. it has MAYBE 3k on it. has some very slight shaft play but hardly noticable. came from a 05 chevy diesel truck. there is barely any carbon in the turbine section.
-plate says GM-1
-3" inlet
-T3 flange
-v-band 3" exhaust outlet
-would definately be easy to use because the exhaust inlet and outlet are on the same side. perfect for a subaru.
-the turbo does come with a wastegate. it isnt shown.
-is oil cooled only
looking for $300 shipped.
