What normally goes bad in a 5MT?
BSOD2600
Post by BSOD2600 »
Since my 4EAT is slowly dying, I'm going to have a used 5MT swapped into it, in about a month. Besides putting on a new clutch and flywheel (if needed), what else should be replaced? Basically what things typically break, that I should replace while the tranny is still not installed?
'11 WRX Limited
'94 TW | R.I.P.
Splinter
Post by Splinter »
Replacing the synchros would be a very good idea.
Olivier
Post by Olivier »
Yes change all the synchros.
My friend have blown 2 5mt an is now on number 3 ALL of the 5mt was grinding in 2. and 3. gear. and et somtimes get really nasty when it gets hot...
