FS: 90-94 Legacy Parts - Everything
SubaruVanagonguy
Post by SubaruVanagonguy »
I remove the engines from 90-94 Legacy (usually NA) cars to do engine swaps into VW Vanagons. I remove the complete engine from the AFM to the flywheel/flexplate, the complete wiring harness and ECU...
Often I scrap the rest of the car because I don't have room for the parts chassis, or the time to pull the partsoff.
Many, many good and parts have gone to the crusher.
This seems like a terrible waste...
So I'm willing to consider standing orders for parts that are easy to ship or can be picked up locally in the San Francisco area (Richmond).
Minimum order/must be at least $35-$50 worth to be worth the trouble.
Place your order and chances are, I have it....or WILL have it soon.
Warren C.
Tone-us
Post by Tone-us »
Sweet..... I'm looking for a working OEM CD player that came in some legacy's... if need be I'd buy the whole stereo as well. Please let me know if you find anything. Thanks.
Threshld1
Post by Threshld1 »
So no motor parts? Looking for a known good turbo FPR and IAC
93 SS 5MT - TD05H-16G, 06 TMIC, Walbro, Zeitronix WB-02 - Scrapped too much rust
91 SS AT
97 Outback - Prodrive quick rack, DMS 40
SubaruVanagonguy
I normally use all the engine parts but keep some spares around or can get them.
IAC - I have the NA version....is that what you need??...or are they the same on NA and turbo engines. Also I think they are wired slightly differently in the 90-91 version vs. 92-24. Which year is your car?
"FPR"- not familiar with this acronym....what is it??
WC
Threshld1
Post by Threshld1 »
FPR = Fuel pressure regulator
and the turbo IAC has a 90 deg bend on the outlet where the N/A is straight so no an N/A IAC will not work, thanks anyways Frank was able to help me out.
91 SS AT
Soul Shinobi
Post by Soul Shinobi »
I have a 1992 Legacy L which does not come with a rear sway bar (properly known as a stabilizer bar or also an anti-sway or anti-roll bar). I don't know if a sway bar is too much of a pain for you to ship, but I also need several mounting components. I need:
-Rear lateral links with endlink mounting tabs (mine do not have mounting tabs)
-Endlinks
-Swaybar mounting brackets
I need these complete with screws/bolts and such. If you think you can ship me a sway bar too, I'd like the proper bushings for it too.
-Nick
1992 BC Legacy L Sedan AWD 5MT 272,000 - Wish you the best
1998 BK Legacy L Wagon 5MT 234,000 miles - RIP
2002 SF Forester S Wagon 5MT 215,000 miles - Current winter sleigh
1986 FC Mazda RX-7 GXL Coupe 5MT 155,000 miles - Summer cruiser
sacsubie
Post by sacsubie »
Dose it have decent hubcaps?
[size=100][b]93 Legacy L Wagon AWD - N/A - Auto[/b] - 155+k Miles[/size]
- [b][u]Swears by[/u]:[/b] Sea Foam - Deep Creep, Trans Tune, Motor Treatment
HobbyWrench
Post by HobbyWrench »
I could use the sunroof glass from a '90 - '91 Legacy Wagon ('90-'91 Sedans and all '92-'94 have a diff't part number for this).
Thanks!
Mike
'90 Legacy LS Wagon, EJ22, NA, FWD, 4EAT - 289K Miles (Girlfriend's Car)
'94 Legacy L Wagon, EJ22, NA, FWD, 4EAT - 200K Miles
'96 Legacy L Wagon, EJ22, NA, AWD, 5MT - 104K Miles
'09 Outback, 2.5L, AT - 64k Miles ("Company Car")
awdwagon
tranny
Post by awdwagon »
i am looking for an automatic tranny. is yours 5 speed or auto?
spdracr
Post by spdracr »
i need the clutch cable, and clutch mounting bracket and clip.....
farfrumwork
Post by farfrumwork »
Also looking for sunroof glass, but for a 92-94 Legacy.
thanks,
Chad
Old - '93 T-Leg - 14.693 @ 92.68 at 5800ft ASL (Bandimere Speedway)
New - 07 Spec B/stg 2
"bloodstains - speed kills -fast cars - cheap thrills -rich girls - fine wine
i've lost my sense - i've lost control - i've lost my mind" Agent Orange
SubaruVanagonguy
Re: tranny
awdwagon wrote:i am looking for an automatic tranny. is yours 5 speed or auto?
Sorry,
All the cars I have currently became engine doners because they had bad trannys.
Warren
SubaruVanagonguy
spdracr wrote:i need the clutch cable, and clutch mounting bracket and clip.....
Sorry,
All the cars I currently have are automatics.
Warren
SubaruVanagonguy
farfrumwork wrote:Also looking for sunroof glass, but for a 92-94 Legacy.
thanks,
Chad
We had one sunroof glass we were saving,, but I think we recently threw it out.....I'm not sure what year it was ....
I'll double check to see if we still have one...perhaps my shopmate can remember which year it came from......
SubaruVanagonguy
Parts request
Boy,
You guys are all asking for the hard stuff....
Nobody needs headlights taillights, grills, interior parts ????
Warren
VRoman
Post by VRoman »
Here you go, the easy stuff: both headlights, both front turn signals, air filter box, the box that holds radio and front panel, rear speaker covers, cargo cover and brackets for it (wagon), OEM jack, passenger front fender (white), radiator grill with the Subaru symbol, and a bunch of screws and bolts.
Since I have so many little things I need for my car, I was thinking about buying another Legacy for parts. But it won't worth towing a car from CA.
PS. I wish you had cars with MTs. :)
SubaruVanagonguy
VRoman wrote:Here you go, the easy stuff: both headlights, both front turn signals, air filter box, the box that holds radio and front panel, rear speaker covers, cargo cover and brackets for it (wagon), OEM jack, passenger front fender (white), radiator grill with the Subaru symbol, and a bunch of screws and bolts.
What year is your car....headlights and turn signals are different for 90-91 and 92-94. I have some from the 90-91 years...only a couple of singles from 92-94...although I have a 92 wagon...currently that I'm haven't yet decided whether to part out or not.
I have a jack.......probably a radio box....several radiator grills.....think had a white fender for a ocuple of years...but think we threw it out in the big cleanup last month.....no cargo cover or brackets.
Where you located?
Warren
VRoman
Post by VRoman »
Mine is a 94, and I am in New Mexico... Also I need right rear tail light.
Actually I'll keep my current fender for now. It has sound insulation inside, and my intake is freaking loud.
Tone-us
Post by Tone-us »
Ever find out about a CD player?
Legacy-Version94
Post by Legacy-Version94 »
Soul Shinobi wrote:I have a 1992 Legacy L which does not come with a rear sway bar (properly known as a stabilizer bar or also an anti-sway or anti-roll bar). I don't know if a sway bar is too much of a pain for you to ship, but I also need several mounting components. I need:
-Endlinks
i am in the same boat... would you be willing to remove and ship these items?
'94 Subaru Legacy Wagon L
[url=http://www.sl-i.net/FORUM/viewtopic.php?p=18605#18605]Mods[/url]
'88 Toyota Supra Turbo
'97 Suzuki GSXR 750
Legacy-Version94
how much for a '92-'94 grill? color doesnt matter.
'97 Suzuki GSXR 750
SubaruVanagonguy
How about $25, ..to cover the grill and my time to pack it up for shipping.
Warren C.
kleinkid
LSI trunk lid labels
Post by kleinkid »
I need the trunk lid labels from a BC LSI, the model with the leather interior. They go in the corners of the trunk lid, rectangular shaped, about 6" long 3/4" high. Need them for a '94.
Legacy-Version94
SubaruVanagonguy wrote:How about $25, ..to cover the grill and my time to pack it up for shipping.
Warren C.
pm'd you. if you can, make sure it has all the mounting tabs/clips intac.
'97 Suzuki GSXR 750
mxxm
Post by mxxm »
how much for fenders out of a 92 ship to 12508?
