Start time: 4:30 pm
End time: 10:30 pm
Damage report:
Several 10mm fender bolts broken
Couple 12mm bolts broken
One dethreaded control arm bolt
One broken 19mm socket
One massive gear oil spill, der da durhhh
One gashed finger knuckle
Progress:
I put that clutch in over a 100k ago.
After everything is torn down, I'll take the 5MT apart to rob it of its stub axels for the 6 speed, strip the EJ22E of everthing but the shortblock minus oil pan, and the list goes on for about 12.4 miles. I'm shooting for less than eight weeks on this build. It includes:
installing new motor I built (http://www.bbs.legacycentral.org/viewto ... highlight=)
rotated mount
rebuilt (custom) lower rad suppt
relocated rad
FMIC & plumbing (behind headlights)
modified wrx exhaust
rewire for standalone (G2)
plenty of other wiring for Zeitronix, gauges, etc
complete rear driveline teardown for bushings
adding rear swaybar/boxing in mounts
reworking pretty much the whole fuel/vaccuum/pcv/everything system
This has been in the works for soo long its almost surreal.
