Cigarrete plug
jpoyann
Cigarrete plug
Post by jpoyann »
Hi,
Just an ask. Is the cigarrete plug 12 volt or 13,8 volt?
I want to conect my laptop to the cigarrete plug and I bought an adapter. In the intruction it recommends to unplug during starting the engine. In not sure if its so important.
Thanks for your help
jose poyan
Subaru Legacy 2.0 Turbo 4WD Sedan
It's 12 volt
Saskatoon Subaru
Post by Saskatoon Subaru »
yea its 12 but i wants you to unplug it during starting the car because the voltage in will raise to about 14 volts
2010 Impreza WRX - 265hp
1990 Legacy 267,000km(Rebuild complete 265,423km----March 9/2008)
1991 Legacy Turbo 180,000km
scuzzy
Post by scuzzy »
1990legacy wrote:yea its 12 but i wants you to unplug it during starting the car because the voltage in will raise to about 14 volts
it'll actually fall to about 10 volts, IIRC.
I've fried inverters by leaving the laptop running on them and then cranking the car, lower voltage = more amperage pullage = more smokage.
#82 M4 TRSCCA Rallycross
Manarius
Post by Manarius »
I've fried lighters from running inverters on them :wink:
jpoyann
Post by jpoyann »
Ok,
So the voltage is 12 Volt with the car stoped, it falls 10 Volts during start, and it stays about 14 Volts with the car running.
Is that wright?
so, I can not plug 12 V electronic devices not made to be pluged to the car?? Others devices like laptop adapters or inverters must be unplugged ???
jpoyann
Post by jpoyann »
Hi, it's me again.
What do you recommend me to use the 12 Volt laptop adapter or the original 240volt adapter + and inverter?
thanks you
Use an inverter intended for auto use. A good one will have a auto-reset circuit that will pop if you leave it plugged in during start up. The one we have at work will shut off and give you a high-pitch alarm for a second, then you have to unplug it and wait a few seconds for it to reset before using it again. All 12V cars (almost all of them) run 14.4 VDC. If an accessory is meant for a car with a 12V system, then it's safe to use.
jpoyann
Post by jpoyann »
Thanks you,
I'll find a good inverter.
