What intake manifold did you use, any issues, injectors, etc..
How did you fit the cam sensor on those pulleys, thx for the help! Mat
Those who swapped dohc 2.5rs head, questions!
92 l swapped to ej22T with 2.0T shortblock
4.111 manual 2.5RS tranny, sti eng mount, wrx I/C, MBC, WRX turboback exhaust, WRX front seats, STI rad cap, WRX specR1 struts, Eibach springs , leg turbo front brake, WRX rear brake.
I am running 99rs dohc head with ej20g manifold dont know what year, also the cas just goes in the stock postion on the driver side intake cam. Stock fuel injectors fit fine may have to re run some coolant, vacum lines, fuel lines, and a few bolts that are to short. I think thats it. I also switched from parllel fuel line were the fuel just flows in a square to parallel set up where I have one line T'd to the feed of fuel rails, and the returns T'd to external fpr then back to the stock lines.
One of the crazy's boosting a NA!
14.3 @ 93mph
14.3 @ 93mph
