unorignal question = can a ej22 be rebuilt into a ej22t
I'm thinking of doing either an engine swap or rebuilding a ej22.
What I want to figure out is weither i could rebuild a ej22 with ej22t parts (makeing it a ej22t, since i can get a n/a cheaper), and what parts are different. then also will my ECU handle a turbo or do i need to piggyback.
or am i trying to hard to be cheap, and it would be easier to just rebuild a ej22t and swap it, then what mods do i need (ECU?....etc)
My thought is to find either a ej22 or ej22t and (slowly) rebuild it with performance parts while still driving on the stock ej22 in now. Now I'm assumeing that if i use performance enternals i'l need to piggback too?
I'm really new with subarus, worked mostly on (old) domestics before, so just tell me if i'm an idot...
or should i just sell a testical to science and buy a new STI
and P.S. I know this Q? has been asked proably a million times I just couldn't find one on here that really anwered my questions.
90-94 engines used the same crank and rods. Swap the NA pistons for turbo pistons. Find some used ej22t heads, or modify your stock heads. Then you are set for up to 250 whp.
do realize that while you can make the internals as strong as an EJ22T, the actual block is different, and much stronger.
for what it would take to turn an EJ22 into an EJ22T you're better off just buying a used EJ22T block.
#82 M4 TRSCCA Rallycross
Nope. EJ22E's are SOHC like their EJ22T brethren.rfizzle wrote:ok correct me if i'm wrong but my ej22e is DOHC and a EJ22T is sohc??
I don't know for sure but I would think it would take a lot of boost and abuse to egg the cylinder walls. To make a difference between the closed block and open block. I've never heard of anyone warping them but then I tend to miss stuff.scuzzy wrote:do realize that while you can make the internals as strong as an EJ22T, the actual block is different, and much stronger.
///M
'93 Legacy SS - part out
- quasi-mod-o
rfizzle,
If you are serious about pursuing this, I would be happy to get involved in your project and help you reach your goals. (note location
) I love messed up projects like this. I even have a core Ej22E block that I would sell you super cheap to get you on your way.
Warren at the Engine Shop in Longmont can do the machine work it will need prior to rebuilding.
Then there are really two ways to go with this. You can use stock turbo Ej22T heads (I also have a set of those available) and turbo pistons OR, you can use stock Ej22E NA pistons and DOHC Ej25 heads. Those heads are easily converted to turbo use since they are based upon early WRX heads. The advantage of that approach is that they flow about 20% better than Ej22T heads.
Anyways, drop me a PM and we can chat. I've done a few projects like this with other locals, and they are always fun and educational...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
which ej25 heads do you use?
these are off wikipedia:
EJ251
SOHC Usage:
* Impreza 00~02 (US)
* Impreza Outback 02 (US)
* Forester 00~02
EJ252
SOHC Usage:
* Legacy 00
EJ253
SOHC
* Legacy 01~02
* Forrester 99
* Baja 03~06
EJ25D
Usage
* Legacy 96~99
* Forester 98~99
EJ25E
SOHC 16 valve
Usage:
* Impreza 99~01
* Forester 99~00
* Legacy 00~01
EJ251
SOHC Usage:
* Forester 00~02
EJ252
SOHC Usage:
* Legacy 00
EJ253
SOHC
* Legacy 01~02
* Forrester 99
* Baja 03~06
EJ25D
Usage
* Legacy 96~99
* Forester 98~99
EJ25E
SOHC 16 valve
Usage:
* Impreza 99~01
* Forester 99~00
* Legacy 00~01
- quasi-mod-o
Good old Wikipedia
EJ25D... used in Outbacks, Legacies, 98 Foresters, and 98 2.5RS's.
EJ251... as best I can tell, it was used from 99-04.
Apparently, there is an overlap between the EJ25D and the EJ251 in 99. I think only Outbacks used EJ25D's in 99.
EJ253... as best I can tell, it was used from 05-up.
I've never heard of an EJ252 or EJ25E.
Anyway, like Douglas alluded to, most Phase I (all the engines in our perspective) have the same bottom end. So you'd be changing the crank and rods for the exact same crank and rods. The pistons are different, dropping the compression. The open-vs-closed deck isn't that big of an issue.
- quasi-mod-o
There was overlap in '99 The outback, Legacy GT and Forester all got the DOHC engine in '99. While the 2.5RS got the first of the SOHC engines.
And there's really no functional difference between an Ej251 and Ej252. It's just a difference of which car they were in...
Suby Hai!
Suby Hai!
