Hi all, just found out the CEL code that shows my O2 is gone and now I have 3 options from the local parts shop!
The shop that I asked has 2 different brand O2 instock and 1 they have to order!
The 2 they have are NTK 24524 and Bosch 13255 both are OEM replace parts for 92 Legacy turbo.
The other one that they have to order is the Walker 250-24000.
Please gives me some more info on those 3 o2 sensor above and which one should I got for my car and make it run back to normal!
Thanks!
Ben
Which one is the best O2 sensor?
ej22t
92 Legacy turbo with EJ20G engine swap \(^0^)/
The O2 sensor for the NA is usally cheaper, and it is the same, except the wire is a little bit longer on it, making it an easier install.
Ask them the price difference between the Turbo sensor and the non-turbo sensor, then tell them to get you the non-turbo.
they both work, but why not save some easy money,
saves you much $$$
thanks
saves you much $$$
thanks
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
