WRX maf sensor
Snorkus, filters, throttle bodies and intake manifolds.
00imprezars
WRX maf sensor
Post by 00imprezars »
ok ive been doing alot of research on here all day and found mention but no actual fact that this could work.
my setup will be sohc rs heads with a wrx intake manifold run a vf22.
now i would run it with stock pipes into a stock 02-up wrx intake box. can i use the wrx maf sensor?(along with a safc or something)
this is going to be on a 91 leg turbo
thanks
stipro
Post by stipro »
What year wrx?
A USDM Wrx does not have a MAF sensor, it has a MAP sensor.
00imprezars
stipro wrote:What year wrx?
oh so any usdm wrx/sti uses a map sensor right after the air filter right?
thanks
00imprezars
i dunno, i was under the impression it uses both, can anyone clarify?
stipro
Post by stipro »
Sorry, you are right, the wrx does have both. However I dont think it would work, but it may, just because the calibration/tolerance would be different. I think they even have a differnt number of wires. But who knows, it may work with some re-wiring, and a wrx ecu.
00imprezars
what we need is someone that is smart with electrical to make a maf translator like dsm's do being able to use the gm maf.....someone must know how to out there
You need to have the transfer function equation for both MAF sensors before you can really do anything....that's really the issue.
