TMIC INSTALL UPDATE (10/12/03) !!PICTURES!!
Front, Top, Air, Water.
David Carter
Vendor
Vendor
Post by David Carter »
Ok, this week, i plan on doing the Saab IC install for better or worse.
Everything is pretty much here, I'm still sourceing a metal pipe from the turbo to the IC..so i can plumb my BOV into it,
This is what i got so far:
I have to Give props out to: Joe P. MBC, Rallitek, and Ebay!
Total cost is under 300.00
RalliTek custom made a Turbo intake for 169.00 it includes the following:
Again if you notice.. NO INSTRUCTION INCLUDED!!! and that makes me nervous as there are more hoseing included with this kit...so more chances to F#@K up... also...sigh no sticker..I asked for both but got niether...they said they'd walk it thru with me over the phone....Thank GOD for weekend minutes...But still have no contact info for them for the weekends as they are not open on weekends..so it looks like i'll be intalling in the dark again.....
Joe.P MBC was $45.00 unfortunately the sent me an Mazda Speed Fuel cut defender:
SO..wink wink nudge nudge,.. if anybody can tell me if i can use this..many thanks ahead of time.. other wise..to EBAY with it..or something.. Luckly my BOV i won on Ebay CAME with an MBC..
So i'll just swap out with the Joe.P MBC when it gets here....
I'll also be putting on the Proto-type hood..so hopefully that all will go well this weekend. 11psi will be a welcome feeling..
I will submit photo's on monday let you all know how it's all going..
David Carter
91 Subaru Legacy LS 2.2l FWD WGN
91 Subaru Legacy SSDN 2.2t AWD
legacy92ej22t
Post by legacy92ej22t »
Cool! Can't wait to see the end product. :D
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Aaron's ej22t
Post by Aaron's ej22t »
I bought the same intake and was at first a little dissappointed. (it is still not installed) he said he would email me instructions either today or friday. i will send you some as well. you paid $169. i paid $100 shipped.
92 Legacy Turbo \ 5MT \ Silver
georryan
Post by georryan »
Is this intake kit only for the saab intercooler?
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
legacy92ej22t
I'm sure the intake is to the compessor inlet only, so it has nothing to do with the compressor outlet to ic pipe. Should work on any Legacy Turbo setup. :)
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
David Carter
Vendor
Vendor
Aaron's ej22t wrote:I bought the same intake and was at first a little dissappointed. (it is still not installed) he said he would email me instructions either today or friday. i will send you some as well. you paid $169. i paid $100 shipped.
Aye, i was bit diapointed as well.. the N/A is big..compaired to this..Huge even.. But the size won't bother me to much as long as it performs..And everyone i see with the intake has a sticker on thier tube... WHY the piss am i getting gyped for the same $169.00 they paid..
...as you can tell i'm kinda miffed about the instructions and sticker issue.. I Called just as they were putting it in the box.. I asked SPECIFICLY for 2 stickers and instructions... I got "Uhuh ,ya sure, will do; Putting it in right now" ...
They are great when it comes to over the phone info..but customer sevice...3 outa 10..
I'm gonna give-em a call today see if i can't get the instructions sent to me as well...to much hoseing to guess..
Please send me what you get..if for some reason i don't
David Carter
David Carter
Vendor
Vendor
THE MISSION...COMPLETED!!! TMIC INSTALL..
Ok please bear with me..this will be long.. but lots of pictures!
I know some of this should be in the intake section as well..so i'll repost some of this there as well.. but again please bear with..
Day One/Rallitek Intake install review.
Day one's objectives were to clean up the vacume lines and install the Rallitek Turbo Intake. Before i start beating this system up over it's many faults, Sean has been exteamly helpfull even though i griped way to much. Also this Kit is a custom job, it's NOT a featured product that they sell..they have more of an idea to do a full COMPLETE intake..but untill then this is what they have..And it works.. with some fanagleing..
We started by removing the stock air box,
and moving down the intake assemblie when we ran across our first leak of the day.
Who ever owned this car first...either did this himself as a quick fix..or brought it to a BAD mechanic.. the pipe at the base of the resonator box broke off, and they epoxied/or something the rubber hose to the box..inside the hose was a nylon pipe to complete the circut..needless to say that probably lasted a week before it broke again..
The next leak we found was the BOV pipe was split past the clasp..
I don't have a picture of the other leaks but the stock elbow is split really bad.. i have it JB welded for now but come monday i'll be ordering another one..also the bov connection on the elbow cracked off..so again i have it rigged till i can get a new elbow peice.. Again it'd be nice if the kit removed this and completely replaced it..but for now you'll have to keep this restrictive peice.
Now once we had the intake completely off we took the time to completely replace the vacume line system, most of which was dryrotted, heat expanded..or cracked. I know this picture dosen't show it but we zip tied most of these so it dosen't look like so much speggetti..
As a side note i RECOMEND this to EVERYONE..replace your vacume line system.. i normally run 6-7 Psi at peak.. after the vacume lines we're replace i've noticed a very strong 9-10PSI at peak..with no flutter or hesitation.. and the fuel smell went away.
This is of course how the instructions want the intake installed. Also the instructions want you to save the stock bolt that hold the maf to the box, so that you can use them to attach the plate adaptor to the maf.. unfortunately.. the bolt part of the screws is pop rivited/welded together to the box.. what i recomend is useing the 4 bolts that close the box and thier matching bolts, that you have to pry out with a flat head screw driver. other wise head to home depot and get new bolts and screws.
UNFORTUNATELY the way they have it in the instructions will not fit the space available:
So with some creative cutting with a saw-zall you reomve like an 1, 1/2 from the elbow
and move the sheath they provide down the elbow a bit more.. or you can cut the nice pipe they give you.. i chose the crappy rubber bit..
Now after the intake is intalled and all the vacume lines are attached.. your still left with the large oil re-circulation pipe that used to go to the resonator pipe..
Ralliteks directions are to use keep puting pipe within pipe untill it reduses enought to get it into the secondary hole they provide..i chose to go Back to auto zone and clean them out of connectors.. it finished up like this:
It was a pain at points but with a bit of elbow grease and fabrication, it all goes together
Special tools...hmm.. I found that my Dremel, and SAWZALL were invaluable tools.. i used them ALOT this weekend.. i had alot of tools
The kit Fit, still with all my trimming..is very tight.. there is no play..which i wil have to adjust later. Weight..is about 3-5 pounds.. the old system is easily 13+ lbs..
this is everything the kit replaced.. Cost.. i probobly spent close to $40.00 getting this to fit/install.. Time..we started at 11:00am and were up to 7:00pm finishing up minor details. not counting clean up..
Was it worth the $169.00 Honestly for that money they need a specificly designed system, so untill then NO.. Does it work.. YES!.. It has made the car increaseingly more enjoyable. The install has rasied my psi from 6-7 to 9-10 and i haven't even installed the MBC.. i think i've lost a bit of lower-end but i haven't gotten to drive the car like i would like to because i've been working on it all weekend.. other than around the block and up and down the street i haven't gotten to really lay into it.. The Stock BOV sounds like an elephant, blowing his nose..not too attractive.. but it scares people on the side walk.. they jump everytime it goes off.. The turbo is extreamly noticeable..it is extreamly intimidateing..
Down sides.. I now have a really really really low idle.. just above off.. and she wants to stall at every light.. I increased the idle at the throttle body and the problem was gone..
Day Two/ Intercooler Install
The intercooler install has been covered alot, And i have some problems, which i think are directly related to my BOV..hopefully i can get some clarification..smack upside the head..etc..
The only thing i need to buy was a 45 degree pipe.. there are alot of pipes at AUTO-Zone that were 45 but had ribs from the bending process, so i ended up buying a chrome exhaust tip. and then cutting off the knif edge with the Saw-zall
Then i proceeded to de-burr the pipe and clean it up
We got out the torch and with the help of some of my welding buddies we started to slag a hole for the bov
We didn't think to check what we were wlding and 3 min into the welding job we notice that the BOV base is made of aluminum and melting/burning away..
So we stopped with the torch, and broke out the Arc welder and got the 2 to be 1.. This was the only peice we had to fab. everything else was obtainable at Home Depot.
The next thing we did was re-locate the ignitor (i think thats what it's called) so it wouldn't interfere with where the intercooler would sit. We flattened out the ignitors mounting bracket and then re-assembled it and mounted it..this is the best pic i have.
After that it was just some straight forward plumbing.. we reattached the vacume line that was on the stock BOV to the new bov and started the car up.
This was purely coincidence but the BOV points right out the Hood Scoop
Which i think is an Added bonus
Now my problems.. Other than everything being an extreamly tight fit..
the car is running awfull.. It idles perfectly..after a chore of getting it started. i think the reason it idles well is because i tightened up the throtle during the intake install.. and as long as i drive it at idle speeds (i.e don't touch the gas let the car run under idle power) i'm fine.. i touch the gas and she instantly stalls. IF i floor it i can hear the BOV tripping and the car bucks real hard till after 3500RPMs when the boost is at 5psi it seals up and PULLS REALL HARD at 9-10PSI as soon as i let off the gas The BOV Screams and the car dies imediately with a Low oil pressure light/ Check engine light, As soon as i re-start both indicators are off. also when i'm starting the car after it been sitting for a while i get an low oil pressure light that fades away within 20-30 seconds of the car runnning..
Now i'm thinking the whole reason it's doing this is because i'm venting to atmos..which i will be correcting tommorow.. That or my 3 peice BOV is leaking somewhere..???
If anybody can give me some heads up,, it would be much apreceated.
I hope you've enjoyed my tale of folly, and can send some info my way.
I apologise for my rancid spelling. and hope it wasen't to hard to bear.
David Carter
pjgaerlan
Post by pjgaerlan »
Put your BOV bypass hose back on and plug it back into the rubber intake elbow where you attached you new intake.. This way you are still running a Bypass valve for the air to recirculate back into the turbo( I think that is right). My Saab IC setup works pretty well besides the ghetto rigged IC piping to my Turbo. I still need to work on that. One of my IC pipe connectors came apart the other day and Luckily I was close to home and had to limp home in the car not building boost and staying at around 30 MPH. good luck
PJ
mikec
Post by mikec »
I have a question about the vacuum line you used to replace the old stuff. Is it all the same size? The part I'm really wondering about is the line that goes from the compressor to the stock boost controller. It looks like there's 2 different sizes on mine, but I can't tell if you used different sizes for the replacement.
TIA!
David Carter
Vendor
Vendor
mikec wrote:I have a question about the vacuum line you used to replace the old stuff. Is it all the same size? The part I'm really wondering about is the line that goes from the compressor to the stock boost controller. It looks like there's 2 different sizes on mine, but I can't tell if you used different sizes for the replacement.
TIA!
I replaced both hoses and tried to match as best as i could and used the stock coupler.
Also a bit of news.. You can't weld aluminum to steel.. needless to say my weld burst today and i limped home.. i got some 2 inch aluminum pipe and i'm haveing a pro-welder put the two together for me.. Also i ordered the elbow from Becker Subaru, should be in tomorrow..i reset my ECU again.. i have a nice steady idle..even with all the leaks now..
David Carter
legacy92ej22t
TIA!
I just did my MBC today and one line from either the turbo or the wastegate solenoid, didn't really take note as to which, has two different sized lines. It starts as the bigger line and has a reducer coupling to the smaller line on the stock boost control solenoid. I used one size for my MBC, 3/8" IIRC. Don't know if this helps but I thought I'd throw it out there
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
NemesisEJ22t
Post by NemesisEJ22t »
I have that exact HKS BOV installed on my Celica and it leaks pretty badly. It does leak when the car is idling, try this: pinch the small vacuum hose going to the BOV and plug the vent hole with your thumb while the car is running. See if that changes the idle at all. Also check your connections again to see if they are all where they should be, or if they are loose. Good luck fixing the problem.
Ben
91 Celica All-Trac @ 0 psi (turbo being installed)
92 Celica Turbo FWD (swap) @ 12 psi HOLY CRAP!!! I miss AWD
David Carter
Vendor
Vendor
HKS BOV
Well needless to say my BOV is a constant problem.. the initial problem was it was suposed to come with a spring to hold the diaphram down.. which i was driveing around with out.. So while i wait for a replacement from HKS.... i sourced a spring out of a fullsize MAG Light thats in the battery cap. so far that works to rid me of my idle problem.. now i just have to live with this annoying fart noise at boost because after the first blow off.. the diaphram dosen't re-seat properly.. and it farts..and it's loud and annoying..
Anywho i'm in the market for a piston/spring design BOV.. instead of that rubber diaphram/spring combo..
otherwise the car runs..
David Carter
J-MoNeY
Post by J-MoNeY »
How does your car run with the intake and cone filter? I have adapted many a cone filter to MAFS and it royally screws with them if there is turbulent air. Just in general they suck with cones on them.
98 LGT
bignose
Post by bignose »
really dumb question.
when you replace your vacuum tubes, did you have to get the spec / diamater/length for every single one, or do you just buy a vacuum tube kit for a 199x legacy ?
http://www.bignose.ca/legacy/pics/
J-MoNeY
Post by J-MoNeY »
bignose wrote:really dumb question.
It looks to me, that he just went to an online or local parts store and bought the standard silicone hoses that come colored in the "performance" section. There are all colors under the rainbow if you just look. The do dress up the engine bay nicely too.
98 LGT
