Need to convert an air/pneumatic suspension leggy to conventional setup. I have some '04 wrx springs/struts that I picked up.
Since I am converting I need new tophats, and if I understand it correctly the 90-91 tophats work for the '04 struts.
My question is if I can just use the '04 tophats in this conversion?
TIA... I have read the sticky quite a few times but it is reading a bit like galic to me right now.
Will '04 wrx tophats work...
cyberbackpacker
-Kevin
cyberbackpacker
cyberbackpacker
clark kent
- quasi-mod-o
