N/A vs turbo swapability in SS
Binford
Post by Binford »
If I were to swap in an N/A trans into my SS I could still use my turbo clutch setup, correct? I remember seeing pics of someone swapping the hydrolic clutch setup onto an N/A trans but now I can't find it. I just need some verification. Thanks. :wink:
Bheinen74
Post by Bheinen74 »
the turbo tranny pressure plate is a pull type, and it will not work on the NA tranny which is push type.
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
Splinter
Post by Splinter »
Other way around, I think
Turbo is a push, NA is a pull
Post by 555BCTurbo »
Splinter wrote:Other way around, I think
No...Bheinen74 was correct
Binford
Post by Binford »
Yes, I realize the difference, but I'm 98% sure I read about someone here that swapped all the different parts over onto the N/A tranny. What exactly would stop me from using the hydrolic/pull type setup?
Post by entirelyturbo »
The only way you can swap between cable and hydro is if the clutches are the same type.
Hardy (THAWA), last I remember, had a 98 RS tranny in his Legacy. Originally setup for a hydro clutch, he said the spot for the pivot ball was there for the cable fork, right next to the one for the hydro fork. Thus, he was able to use a cable-style setup.
But, the tranny he used was still a push-style. If you want to use an NA tranny in your SS, you'll have to get one like Hardy's, and you'll have to get the hydro setup from that car.
Ultimately, just use the correct tranny. Or, if you're having trouble locating one, use a WRX tranny and rear diff.
*Formerly DerFahrer*
