What's the worst gas mileage you've gotten in your Legacy?
I think you would be hard pressed to beat me. I just filled up yesterday. Put in a bit over ten gallons of gas after driving about 135 miles. Came out with an average MPG of 12.8. This is with about 75% highway driving!
I have a 318AWHP Eclipse, V8 Camaro with gears low enough that it runs at 3,500rpm at 75mph, and a Lexus SC300. I also used to have an 81 Ford Fairmont that didn't have an overdrive. I drive them all hard, and none of these cars have ever come CLOSE to that poor of mileage!
Obviously somthing is up. The car runs beautifully but throws a CEL on occation when I'm cruising on the highway. I'm thinking either the O2 sensor that came on the exhaust I installed is bad, or the car REALLY doesn't like running w/ the HKS SSQV vented to the atmosphere. Last year before the slew of mods I did, I would pull off about 24mpg on average. Probably doesn't help that, with the 3" exhaust, everytime I even think about touching the gas pedal, I instantly have 12lbs of boost in my intake manifold.
19MPG courtesy of cold weather, 20-50w and donuts in the snow.
you need to check your code. This past summer, my 93SS would at times run really awesome, and other times it would bog down, like running only on 2 cylinders. I also had the sporadic CEL, was for Canister Purge control solenoid. I also had a weak coil, causing low spark, and when it was running rough, I hit about 9MPG.
So, have you checked the coil, in addition to your code. Once i switched coil, and the solenoid valve, I was again getting 25mpg.
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
Josh-
Thanks for the link. I'll try to check my codes within the next week or so and I'll let you know what I find. More than anything, now I finally know what those green and black connectors under my dash are for. When I first saw them a year ago or so, I connected them, and when I saw my CEL come on, I thought that maybe the previous owner disconnected them to keep the light off. Glad I know what they're for.
Bheinen74 -
I actually replaced the coil last year with a diamond coil pack. When I did the change then I noticed no difference in drivability or gas mileage. Over this past October/November I installed an MSD DIS-2 amongst my "slew of mods". Since then the car has run much smoother (with the partial throttle hesitation I used to experience all but gone), so I find it hard to believe the car has an ignition problem running the way it has been. I could always disconnect the MSD DIS-2 and see what happens, as I installed it in such a way that I can run the stock ignition in 20 seconds if need be.
I just drove the car over the weekend BABYING it the entire time (accelerating insanely slowly onto on ramps, off of lights, etc.) to the point where I tried to avoid creating any boost what-so-ever (which I found to be impossible...the turbo spools and creates boost under almost any acceleration). Even so, the best I could muster was 18.3mpg - much better, but still far below where I was last year driving the car much harder. I'm hoping the CEL sheds some light on the proble and it's not just that, even when I'm crusing on the highway at a steady 75mph, I'm still averaging about 1psi in the intake manifold.
I've never desired lag so bad in my life.
Bheinen74 -
Well, I managed a new low. 17.59 mpg on the last tank (14.66 gallons on 258 miles). Something about revving the engine to keep it from vibrating so badly really kills the gas mileage.
