I picked up a set of 02 WRX seats and put them in the impreza. They are much more supportive, and pretty easy to swap in.
The seating position is a little different, the bottom cushion is angled up a little, which is different. However when I measured the distances from the mount bolt to the top front portion of the cushion, they weren't that much different....even between the Legacy.
So I may play around with these seats and see how they fit/feel in the legacy. Swapping the seat belt buckle kept from having to swap to WRX seat belts.
http://www.main.experiencetherave.com:8 ... /wrxseats/
WRX Seats in the Impreza
Those are the 02-03 WRX seats.
The newer seats are like the ones in your picture.
I've talked to a few people that have new STi's that did own 02 WRX's, and they like the 02 WRX seats better. They have better leg bolstering and seating position.
I have put 02 WRX seats in a friends 92 legacy Wagon L, they made a world of difference, they do sit a bit lower so the seat belt connector sticks up a bit high but who cares?
Check out this thread.
http://bbs.legacycentral.org/viewtopic.php?t=29668
I posted info about the WRX seats in the legacy.
