Igniter grounding?
magicmike
Igniter grounding?
Post by magicmike »
Does the physical mounting of the igniter matter? Who ever did the ic install on my new wagon mounted the igniter upside down and I want to mount it with the plug on the bottom to prevent water from sitting on the plug. Not sure if I need to mount it to a metal surface or not. pretty sure there is a ground going to the plug already but not sure if it would help to have the body of the unit mounted to ground.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
Binford
Post by Binford »
I never mounted mine to anything when I moved it. I have it zip-tied to the big wiring harness that runs right there.
Yeah, it doesn't matter how it's mounted.
magicmike
Post by magicmike »
ahh well I ended up cutting its original bracket and mounting it on the back side of it and using the 90° bend in it to sit it nicely down under that tower there in the middle for the trans mount. too late for pics because the ic is back in. Thanks guys
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
