SOLD: This is a 93-96 WRX top mount intercooler, commonly refered to as the "slant" style. It looks rough, fins pretty um well you see...nothing some patients and a flat blade screwdriver couldn't fix right up. These mount nicely on T-leg's w/no firewall clearance issues and your coolant bottle can stay in its current location if you rotate 90 degrees. Def an easier fit than 02' up WRX units.
Looking for $125 SHIPPED to any 48 states.
Next we have a nice condition rubber turbo inlet piece. These are NOT a direct replacement for a legacy turbo unit but with some simple PCV routing mods you can easily adapt this to fit your T-leg. Used but soft and pliable, these are expensive from the dealer...
Looking for $75 shipped to any 48 states
The money shot:
 It needs a pressure test though before I offer it up as it looks a little rough.
 . But if it works it works?
