what control arms fit?
bmxkelowna
Post by bmxkelowna »
i need a front right control arm, sway bar end link and tie rod.
what subarus can i get these off of?
i saw this online
BAJA 03-04
FORESTER 98-00
IMPREZA 93-01
LEGACY 90-04
is that right? can i use a control arm from any one of those?
what about the end link and tie rod?
Imprezive
Post by Imprezive »
just buy a brand new one for your car. I know it will be more expensive but why run the rist of getting another bent control arm.
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
n2x4
Post by n2x4 »
When I bent my control arm, I bought a control arm w/ balljoint and endlink from the junk yard for 30 bucks. It was off a 96 Legacy. Personally, I wouldn't get a junkyard tie rod, those are cheap enough, but the list you had seems correct. I don't think a new control arm is needed, too expensive.
SUBARUEHS Racing
mr soul
Post by mr soul »
That list is correct, you could by 4 or 5 used before you get to the cost of 1 new one.
I have this if you need it, but local resources should too.
Keith :D
Retired but still rocking a 98 Coupe with the heart of a turbo legacy :)
jamal
Vendor
Vendor
Post by jamal »
Your list sounds about right. There's not much reason to spend the extra money other than for the fresh bushings. It's not like a new arm will be any less likely to get bent if you run into something else.
My used control arm from awhile back was $35 shipped. My balljoint and wheel bearing also got trashed so make sure they're alright as well. My used steering knuckle and bearing ($45) lasted a year and I just had to have the bearing and hub replaced.
