what to choose?
jake15
what to choose?
Post by jake15 »
so i picked up this 94 impreza wagon a while back. the car is going to be my rallyx/gravel road beater.... and i'm trying to figure out what to do with the motor.
i have a phase2 2.5 block that i could just drop in between the 1.8 heads and have a higher comp 2.5
i have a rotated turbo kit setup i could stick on the 1.8.
or the 3rd option i've been toying with (but i have no $$ for) is drop some STi pistons and rods into the 2.5 block and put the rotated setup on it with a vf39 or something similar (not really feasible but it would be fun as hell :lol: )
all would be run off of the 1.8 ecu with a greddy emanage blue.
so... what do you guys think?
206er
Post by 206er »
I dont think the ej25 block will work with ej18 heads but I could be wrong. would be crazy high compression if it did, like low 12's. trade the phase 2 block for a phase 1, put some cheap ej22 heads on and call it good.
what heads do you have that you could put on the ej18 block to turbo it?
jake15
Post by jake15 »
yeah, i was wondering about that too but i have na and turbo 2.2 heads... so i could use either sets of those also. for turboing the 1.8 i have some phase1 2.5 DOHC heads in iffy condition, some t-leg heads, the stock 1.8 heads, n/a 2.2 heads, and i think thats it....
i'm not really looking for a crazy power car... just something with decent torque for some gravel/dirt fun. i'm kind of leaning toward putting the turbo kit on the 1.8 for now and when the 1.8 blows or i get tired of it i'll swap in the 2.5 and convert it back to NA.
Post by entirelyturbo »
Very soon, I will find out whether EJ205 heads will work on an EJ18. I haven't given up on my project yet.
Remember, then EJ18 is the same as any other Phase I engine, just the bore is different.
There is ONE big problem with EJ18s though: They don't have knock sensors :shock:
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
