I am talking about this sensor if ur wondering, or is it not there on the 1st gen legacies 89-94?
so there is no sensor?????? How will the computer know if its slipping, does it have a mind of its own?Manarius wrote:VSS1 has NOTHING to do with AWD. Torquebind comes from solenoid C issues or worn out clutchpacks.
oh, well i checked my codes, and i got a previous code calling for speeed sensor 2.Manarius wrote:VSS1 only runs the Speedometer. I don't know which sensor lets the TCU know of a speed difference.
Well, I think you should act on that then.ericem wrote:oh, well i checked my codes, and i got a previous code calling for speeed sensor 2.
You are 100% incorrect.Manarius wrote:VSS1 has NOTHING to do with AWD.
*puts on stupid cap*Legacy777 wrote:You are 100% incorrect.
The VSS1 tells the TCU how fast the rear driveshaft is spinning and is exactly how the TCU knows whether to apply more or less line pressure to the duty c solenoid.
ericem,
Both speed sensors need to be functioning properly for the AWD system to function correctly. It's possible the rear speed sensor, the clutch packs, or the duty c solenoid may need to be replaced, and could be causing the binding problems.
hmm, well no existing code is being showed. Im going to subaru tommorow i believe, so they will look at the car, oil changes(diffs, and engine) then they will clarify what exactly the problem is. Thanks.Legacy777 wrote:The speedo is VSS2
VSS1 "shouldn't" have any affect on the speedo. It should however through a code in the TCU.
ok, did it,and when i back up, it binds, and its all wheel drive 100 percent, NO slippage.Legacy777 wrote:You are making the assumption the clutches are completely 100% gone, and would get 0% torque transfer. The likelihood of that is probably slim.
With full line pressure going to the clutch packs, you're bound to get some torque transfer.....even if the clutches are worn to the point of needing to be replaced.
I don't think the transmission will work with the main connector unplugged. These transmissions are pretty much all electronically controlled.
